plane sound frm the full range speakers...
haiyoweiya
Hi to all sifus~
I've just setup an ICE for my car...
But then I start the engine, an audible "aeroplane" sound is heard...
The pitch rises as I rev and the RPM goes up...
Heard ppl advise to put a noise filter/surpressor onto the system...
Will this work? And how to install the noise filter/surpressor?
My current setup:
1400W 2 channels amp powering 2x B-52 10" subs...
280W 2 channels amp powering 2x GLL full range speakers...
Audiomatic Pre-Amp...
JVC HU...
I hope any sifus out there can solve my prob~
Thanks in advance~ :Þ
Using noise filter is bullshit. If possible not to use Audiomatic parametric pre-amp.. so..
a) How many pre-out available from HU?
b) Did your Amp provide pre-out?
c) Did your amp grounding cable properly solder to car body?
oldskolboyz:
If not to use that pre-amp, then any alternatives?
a) My HU has 1 pair of RCA output only...
b) Nope, only 1 pair of RCA input...
c) I tied the amp grounding cable at the seat belt buckle for rear seats...
Cheapo stuff always coz the noise, what U can do is add 1 or 2 grd cable for it & use bigger cable like 10awg.
I understand Ur sitution when Ur HU only have 1 pre-out. Fader & Sub control will be your main consent it's. That why U use Para Q, 95% accs shop will suggest it. That is common practise to them since long time ago.
Some ayam brand also provide RCA output, so U unlucky loorr. If Ur amp got this than U can skip Para Q but U will lost control on Sub
Than U should solder it to car body for each amp, easy way always giving problem & waste time.
oldskolboyz:
Anyway what's Para Q? Sorry I'm noob in ICE~
My amp is Power Acoustic USA, is this brand good?
And another thing, am I require to use bigger cable (as similar to cable for 12V terminal) for ACC?
Sorry again for being noob~ :)
Ur Audiomatic laa.. Pre-amp is general name for all electrical equipment locate between HU & Amp like Parametric equalizer, electronic crossover, line driver & etc lorr. Almost all accs shop call Parametric equaliser (Para Q') is Pre-Amp.
Nope, just for ABC (ada bunyi cukup) only, what U pay & thats U get loor. should be better than Kenbo, V12 F705, Proton & etc.
Can also but it wont settle Ur noise prob.. hee hee.. Cheapest way to eliminate noise create by Para Q" use bigger ground cable (bigger than Pwr cable +12v) & add 1 or 2 more
scrape the paint away where u put the amp ground wire at seat belt bolt. can use rough sand paper, for grounding must always make sure metal to metal, no paint.
relocate ur audio cable and power cable.
do not run them parallel together.
"asingkan" the cables.
oldskoolboys, how to solder ler.. chassis.. need powerful solder.. 100w above.
just sand the chassis. and tied the cable to the bolts firmly.
other u may try is to locate from where the sound came.
remove/disconnect 1 by 1 in the audio system link.
eg: remove the paraQ. directly connect to amp and test.
test all the audio system until u found the sound fom where.
usually either from amp/paraQ/audio signal cable.
from HU maybe also, but urs is branded one, i think no problem.
oldskoolboys, how to solder ler.. chassis.. need powerful solder.. 100w above. just sand the chassis. and tied the cable to the bolts firmly.
kee kee.. I'm using Jln Pasar 1 laa.. just RM8.50 only.. Depend on yourself either U want to improve learning/knowledge/skill or stick at there forever. Knowledge & Exp dont come free 1 but must spend some money either RM10 or more, everything up to yourself to achive it... hee hee......
Thanks to everyone who provides me solutions. I'm currently workin at Langkawi for 1 week, will only be back by next week. Will work on my car next week lo~ ;)
I've recently try adding 3 more ground cables, 2 to the chassis, and 1 to the engine, and even tried using Nakamichi Electronic X-over (EC-204) instead of my previous pre-amp, yet the alternator whine is still there~ :banghead:
How arrrr~~~??? :adore:
last time i oso ever encounter this kind of similar prob. wat i did was i change my RCA cable.. but then, it still wont solve the prob. and the next time i did was to put extra wire at the RCA head at the RCA output of my HU and grounded it to my car body. and the sound gone... mayb this works too but plane noise got many causes.. u shud find the exact cause of the noise 1st..
Try go to bcae1.com they have a step by step instruction that you might be able to follow to troubleshoot your problem.
The additional ground cable should be for your pre-amp or electronic crossover. If this method wont solve, try connect the RCA direct from HU => Amp. If this method also wont solve, mean U need to change the RCA cable.
could be rca, or could be the amp itself....
