New Engine in engine bay and running:
cool!!! 7A is running!!!
how's the power bro?
how to do to get my valve cover crom shining loke eg9 valve cover ya..
well done chu.... evrything going well n nicely done ;-)..... can't wait 2 c d engn perfomance n d car as well....
actually by cromming the valve cover look nice..mayb will do on that..but how abot eng become more heat..is that true..
chu..agak2 how many hp ur new monster ya..like that these weeked mayb try to do the valve cover lo.cannot wait..
less then 150whp without tuning right?!! hehehe....
oh! then how many torque can this 7A produce?
Donno......just done up the exhaust only.
The cam degree is out of spec, I believe most of the powerband already shift to 5K RPM onward due to intake and exhaust cam being advance more then 5 degree.
After run in only can test actual power and proceed with fine tuning for the cam degree, set the proper AFR and reset the ignititon timing.
bro can i noe wat flywheel u r using??? as far as i know,4ag flywheel cnt b use in 7afe engines.. r u using back the 7a flywheel?? n can i noe wat timing belt u r using??? appreciate yr tunjuk ajar
the cam degree is out of spec? wat's that mean?
running high cam with ur 7A?
. So now I need to replace it. How much for the new antenna? Or any better aftermarket? Thanks.
