Modify Clutch height ? Now my gear cant shift
sentro
Hi all,
Can i know how to modify clutch cable to adjust the heigh ?
ok, there is one rubber, and 1 yellow color screw rite ?
we shift clockwise mean it'll tighten and move inside.
What is the right way to adjust ???
Justnow i loosen the rubber, then pull the cable, then i shift anticlockwise to the screw so it'll go outside ....
then i press my clucth the gear cant shift liow !!!!!
then i do do do, the clutch too low till i move 0.01cm the car can engine die off
hope someone is generous to guide me :cry_smile:
i asume ur cable is very loose now rite?
tighten it back, cable is not tight enof.
tight it back as how u loosen it..
leave it to ur mech if u not familiar wit tat...
my mech help me adjust those thing for FOC, so y so troublesome go do urself if ur mech can do for u FOC?
my2cent
not much mechanic in my area, furthermore i wan learn ma.
ok i tight it back oledi now can shift gear.
But actually how do we adjust ??
untight the rubber, then the clutch height is depend on the screw or wad ?
If u adjust the clutch too height , ur clutch pedal no free play .
It probability to burn ur clutch ...
u adjust the cable or the cluth pedal there?
u gotta leave some gap (free play)>>otherwise ur clutch finish/burn kawkaw......
hmm i tot the height onli can adjust from the cable rite ... after open bonet near the injector there
Btw, the heigh of clutch is it affect from the rubber or the screw ??
u mean the rubber too tight clutch burn ? i put it quite tight wor ... but my clutch is not too low also ... so how ah ?
when u press the clucth, ull feel some resistance at some point rite?
dun tighten it till the resistance feels like too high
ya, b4 u feel the resistance, if the gap is too short will not b goodlor...
shit lo like tat... mine like no gap wor...
n i remember tat time my mech help me adjust it.. n ask me to sit inside to feel the clutch.. then i sed ok..feel better..coz last time too low d... then he told me tat adjust till max d... =.="
so..wat shud i do nw?
lessen itlor :) by lossen it, hahaha
hmm look for the cable, not sure abt ur car tho.
satria...hmm, mebbie i'll ask bek my mech to lossen it a bit..
btw.. mind telling me where izzzit? the cable thingy..
need confirmation :
1) is it the rubber mean to loosen the clutch pedal gap ( between the resistance point)
2) is it the screw determine the height ? if so, if i need my clutch lower, how should i adjust screw ... need DIY today haha.
Btw, i think if no ressistance gap nothing kua. Unless you awiz put ur leg there to rest la, then mayb u tertekan the clutch a bit so consider makan loh. If got resistance, u put ur leg there to rest still not kena .
if there is no gap at all, there is a chances for the clutch still engaging....as it is not fully free.
bout the gap, u can feel it by putting ur leg..there will be a free space in between.
if there is no gap, try to adjust it...there will be an adjusting screw at ur clutch pedal for sure...try to looks for it...
i check mine got some gap
but for clutch heigh matter, any anyone confirm for me ...
is it we adjust the rubber or screw ??
i try it few time and the result is random @___@ +___+
