High Energy Plug Wire Set From USA. ProRallye
powergigi
hi sifus,
just wondering anyone used this item before ?
i hope i dont offend anyone by posting up this in the forum. just want to know more about this particular item.
reason coz i think the price is about RM 190. and i have been thinking of getting NGK power cables but they cost around RM 3++
so if anyone can share some info about this item.
somewhat similar to Nology plug cables which has grounding cables...
not sure hows the performance yet... but i'm looking forward to it as i've jz ordered mine from a seller in zth recently.... as for noise interference with radio, i'm preparing for the worse...
4g93
yeah i heard its with the grounding cables
i've sold 2 set of the wire recently.1 is for 4g93t n 4g93.
what i'm disappointed about it is when u plug it in,there's
no clamping what so ever btw the plug n the wire.just
plug in like that n it's just stay there.u can easily take off
the wire just by pulling it lightly not like others that have
to used a bit force to take it out.performance wise,i think
it perform better then ur conventional carbon plug wire.
n it heat resistant too.to bad the wire is to thick so it's
not that flexible.
skywalker,there no noise interference so don't worry.
hi GT auto,
thanks for the info.
but if u say there's no clamping, wouldn't there be tendency of it dis-connected from the plug at high revs/vibration that your spark plugs wont get any connection? which might indeed cause mis-fire or something ? soundsl ike its very dangerous.
anyways could you compare it to NGK power cables ?
skywalker,
yah i know its selling in ZTH thats why it came to my attention :) please do share with us once u have hooked it up . are you currently using the original cables ?
i've heard good reviews from my fellow member as well... thats why eager to try it out...
so far, the item havent arrive... need to rush the seller jor...
yaya, currently on ori plug cable....
hi GT auto,
yalor....that's the problem that i want to point out.let's say if ur engine vibrate
hard enough,the plug can come out anytime.u go n try out first lor if u want
to buy.if u satisfied,then buy.if not,there's other brand u can choose from
like brisk,ngk power n ultra.
received my prorallye cables yesteerday.... installed it... but ground cable really too short la....
overall, a little improvement... smoother throttle response... okla, recommended....
hi guys
thanks for the great feedbacks and advices.
skywalker, when installed was it loose fit or tightly fitted to your plugs ?
Gt auto, do you sell this parts ?
yup.why?u want to buy from me?hehehe.......:_:
about the ground wire on the plug cable,u can
DIY .
ooo.....wat bout spark plug??? whch 1 do u prefer 4 iridium? denso,ngk,bosch or other brand??
hrmmmsss i know it has to be tight fit. but review given by GT AUTO says its abit loose mar.. thats why i ask lor :P
by the way, how to DIY grounding fron cables ?
Ultra cables are from whom ?
powergigi,if u trust me also useless cos u hardly know me right?
why not u go n buy from the m.place merchant.at least u can try
it out first.like i said earlier.if u satified with it,u can buy straight
away.if not,u got the reason why ur not buying it.maybe saga/iswara
is diff cos they HAVE to stick cos there's r no wall on each side of
the plug cable n there's no cap from protecting the plug from water
not like ur's.on a 4g93,u have to insert the plug cable through a hole
on top of the head.if it doesn't click,only the wall in the hole that keep
the plug cable planted in place.usually this kind of problem occur when
the protective cap fouls ur engine head before the tip of the plug cable
reaching the plug it self.
about ultra,it's made in japan.very expensive plug cable.but not as expensive
as nology.
u want to do the ground wire for plug cable ar???ez only.u just buy 4 wire for
each of the plug cable n those rubber that can shrink once u heat it up.what do
u guy's call it??at 1 end of the wire u connect it to ur engine head(any plc will do).
on the other end u just wrap it to ur plug cable.wah lah............ground for plug
cable.:_: .i've seen it at chop shop.those japanese do it on ultra plug cable.
