wat car?........
just need to disconnect the -ve point of battery and leave it for around 15 to 20 mins. then the ECU will be reset to factory setting. so it will record and recognise your new driving pattern style.
there's really no harm doing so.....
it's same as electronic device.....
but why do u need to do that often?!...
like what koolspyda commented; newer ECUs usually are inteligent whereby it would adjust to the drivers pattern and "learn". Unless of course you change your driving pattern every now and than; if not, why do u need to reset?
Usually ppl would only reset their ECU if they've done some mod to their engine; like changed throttle body, install new camshaft, injectors etc.......
Why?....because they wants the ECU to get used to the new "settings".
my carb....cabut and put back also no difference...
but my impreza gc8 hv the socket under dash for ecu resetting bro.....
CEL will blinking after ecu is fully reset.....then u hv to unplug the socket under-dash...
my2cent
Pls check if its diagnosistic socket.
The flahes or "blinking" are coded. Difference flash sequence means something or a component in the engine is out of order.
OIC, that interesting.
SO have you dyno your car befor and after reset ECU, how much torque or hp will gain?
Thanks.
