my BOT gen2
impressive again...
keep me updated too....
now i have a clearer picture...
the max km/h u ever pedal is?
Hello Fren,
Actually max km/h is pointless.
1.3GL Wira can also 200km/h or 1.6 Wira XLi can do 240km/h. But it takes forever to reach that speed and need very very long stretch of road to do it.
The correct benchmark for engine performance should be, how many seconds to reach 100km/h from standstill. (The most ideal benchmark of course would be 0~400m ets)
And whenever someone ask how many km/h max a particular car can do, it reflects their shallowness in car modding.
just a question only...
sorry if i did ask a stupid question....
maybe i not that good as u joeker...but i learning and interested...
but thanks for correcting me...and i learn someting new....
radiator hose gotta change to better one i guess...so near to ekzos areas...later melt :tongwink:
BOV n Intercooler not yet install.just can hear little SHHHH for turbo inlet.
custom thing at shop.install at home.that Y the cost is 4.5k.
you're saying u did not install any intercooler and boosting 0.4 bar now? :shocked: :shocked: :shocked:
nice BOT there... :D
hav u tested 0-100kmh? (^__^)
0 - 100,0 - 400 not yet test.bcoz this is my 1st projek,homemade.cant simply2
high rev.need time to know my car behavour.
but yesterday i try to slowly padel it on h/way eazly can go for 230.
need to change bigger ekzos pipe.when reach 6k rpm my start to feel heavy.
Sounds good... wanna take my old TD04 and put inside the Gen2 too.
seriously engine wont kong ke? this a massive upgrade to campro aspiration
i won't consider 0.4 in soft but maybe 0.3. There is a guy who Supercharged his Myvi and boost 0.4, 1 month plus later he blew his engine. So i dun think its wise decision
im a forum reader and a mechanic 2,0.4 is almost half a bar so its quite high for campro coz the materials is designed for normally aspirated engine internal moving parts cant take the higher compression so most likely u will enjoy the huge low end torque which the td04 is feeding ur campro wit rite now but in terms of longlivety of ur engine could be short and hence when u turbocharge ur engine operating temperature will rise the size of ur standard cooling hoses and the size of the water flow in ur block and cylinder head only caters for normally aspirated performance so its rili not wise to turbocharge ur engine.
oic.im not a mechanic.what is the compration ratio for gen2?
what type of piston gen2 use?
if i tell u,my car boost at 0.2 and gain 130hp,do u belive?...
u know that guy?want to meet him and change opinion.
how he boosting his car?
what engine management his using?
td04 will run out of breath at high RPM.
Enlarging Exhuast piping will not solve your engine feeling heavy at hi RPM.
You need bigger Turbo Compressor (but that means more modification and more $$$ need to be spent)
M1adam has a point though.
Whatnever engine tat is modded, the lifespan and reliability will be affected.
If you don want to have any engine problem, DON MOD IT.
However at 0.4 bar, the engine should be alrite as long as air fuel ratio is properly tuned and regular maintainance and check-ups is done.
My old car, the 1.6 Wira Auto XLi BOT boosted 0.5 bar for almost 2 years. Other than the Auto gearbox cannot take it (Wira 1.6 Auto gearbox are nototiously know for), no big deal ever happened.
YES....dun MOD it.ekekekeke.
next mod : change to td05
thanx for the info bro.me just a clerk.
nop. i dunno him. so i guess those question u better ask him. what do u mean meet him and change opinion?
