slip..heheheh tat need lsd gearbox la...hehehehe...
where can get lsd gearbox for BT/SVT engine huh...
i think if use lsd ...can get better timing woo..just my 2cents
engine same.....but car body different, rim size different....some use rsm. (only 1 driver),...some additional 1 person at pessanger side......result also different....
mine? not so fast lah...
estimated 8 sec around that. RSM. best is with two person, banyak "taik" dalam hahahahhahha..
to clock time and compare like this, need to be the same way of RnD.
rsm or other electrical devices. to be more accurate, got G-sensor for RSM. the error from wheel spin can be corrected using this G-thinggy.
my view: LSD should improve your time a bit. give traction during starting.
some minor2 things to consider:
rim and tyre size
fule (ron97 or ron100)
gear ratio and finale drive can consider as contributing factor issit? or more like .secret weapon.? hahahahhah
I've been throwing around the idea of possibly competing in next years MMER at Sepang. I want to use an S8 RX7 (S6 or S7 if its allowable) as my platform. I had a look at the regulations and its quite vague...
