CAn Anyone Help ME pls
lbk182002
HI THere TO all ICE Sifu out there
CAn Anyone pls tell me that
For CApacitor
what the use of it
and is there any improvement for the sound
this is the spec
Clarion CD Player(DB 256)
Kickers Impulse I5.2 component speakers
America Sound CEX-800 Elec Crossover 3way
America Sound 2Channel Amp CS 50.2(For Mid)
America Sound 2Channel Amp VL-800H(For Sub Woofer)
Tomahawk 12" woofer(2pcs) c/w
Open Vented BoX
depends on your intention of using the capacitor.
If you want to use it on the power supply to amp to get louder bass then it is not worth buying it.
If you want to use it on the audio signal line then it will function as high-pass filter. Good if you want high frequencies only going to your speakers and you do not have passive/active crossovers to do that job.
if your lights dim when the sub bass kicks in, then it can help a bit, but more importantly it doesnt cure your alternator & battery charging problem. if your a bass kaki and play loud a lot, then i guess theres no harm in adding it..
thanks to you all for the explaination lol
but i heard that izzit that if put the capacitor besides the amp for the sub
it will make the bass more harder
and also it will help the light not much blinking ah
cause everytime my sub(boom)
the light starts blinking
izzit the capacitor will help
u need to get the spec of RMS consuming from ur setup....
add in calculation of the size of ur battery
if cannot support, than get the right size of capacitor. ur head light blinking ah?
HI There BV5015 The THe AMP SPEC
AMERICA SOUND HIGH CURRENT AMPLIFIER
MODEL: VL-800H
RMS Power: 200 Watts per Channel
Frequency Response: 10Hz - 40Hz
Input Sensitivity: 200mV ~ 4V
Input Impedance: 10K Ohms
Channel Separation: 60dB
Damping Factor: >200
Total Harmonic Distortion: 0.05%
this the amp i going to put capacitor
i not sure about my car battery
i thinking puting 1.5farad lol izzit ok
mmm... if 1 farad capacitor can use up to 300 watts.
lick this link below to learn more.
http://www.gr8tunes.net/forum/showthread.php?t=7759
u can use both amp also can.
Try Helix Power Station. its can connect up to 3 amp wihtout no problem bro.
one more question
is the capacitor only use for sub amp
and the mid amp how
depends on the amp power, usually 1F capacitor for 1000W of amp, so if the total of your amps are below 1000W then u can connect the amps to one capacitor, if more, then u have to get more than one capacitor...
not really. for loud bass, sub is what plays the most, and that is the one that requires the most power, since the subs are the largest speaker in the system, so cap for sub amp is the one that can make any difference. unless youre charging system is bad, u wont get any difference if use cap for component amp...
Why so susah? Offer him cheap cheaplah. That thing will solve your bling bling lights. Ooops, the cost is higher than both the amps + HU+ speakers:shcokedcamo:
:_: i think u change alternator more better. around 110 amp:regular_smile:
if u wan more good result change 70amp battery.:_:
using bigger batter only helps when listening musik longer in parking.
