Stay away from Silverstone ftz sports. Shitty on wet roads but dry road, not too bad. Actually, I've never came across a single tyre that is good on wet road.
bravus barum... last time bought rm145 per piece for 195/55 (1st time launching dat time, promo price la..), bridgestone turanza pun ok, around rm160 i think.. silverstone kruzer not gud one, very soft, of coz gud grip but easy to tear.. most of stock gen2 using dis..
grippy and wears fast....hm.... i lways travels..let say i done 5000km in 2 month.. hmm... luka..whats the price for both?need for my front tyres.. dunlop sp at front still a lot off thread..but my yoko at rear almost finish...
is Yokohama S306 195/55/15 good? this tyre still in production.. ?
im not sure about 15" tyres..
i used to use for 16" 45 series... yoko es100 is a bit cheaperrm280+-, Falken ziex is consider expensive range rm300++
but thats the price for low profile.. for ur case.. maybe cheaper.. n tyre prices changes according to rubber prices.. im not sure how much izzit now
if u use this 2 brand of tyres with such mileage... i bet just after within a year + ull need to get a new one.. but it will not wear as fast as 45series tyre...
Goodyear GSD2s, GSD3s should be the same if not improved...
You still break traction in the wet but recovery is very quick.
I got into a minor accident and scratched my rims in the wet after switching from GSD2s to Potenza GIIIs. Car wouldnt stop sliding as I was used to. : /
for me silverstone ftz evo8 is good!wet road is not a problem...runs water very well!price are not so expensive,affortable!i got it rm175 per piece
slighty better than good year nct5....
As most of you would've known, by using a metal clutch (single, twins, triple etc) it would give a ringing sound when the clutch pedal is depressed. Once the clutch engages and in gear, the noise would no longer be...
Hi all. Need some advice here. I have recently purchased a set of rear disc and caliper which was claimed to have come from Mazda RX7 FC3S. Can anyone here verify if this is accurate (please refer to pics below)...
i'm just help my friend to find evo5 airflow sensor...
but not sure the code no....
if u have evo4 airflow sensor also can consider....
1 more thing... i need help to find evo4 airflow sensor wiring diagram...
