Some of you might want to find out which plug cable deliver best performance for 20V. Following table shows the resistance value of few after market cables that i had measured by using DMM. Perhaps it can give you some idea on how it's performance looks like.
< STOCK (5mm) - RM300 >
Coil to Dist - n/a
Cable (1) 5.16k Ohm
Cable (2) 5.90k Ohm
Cable (3) 7.50k Ohm
Cable (4) 8.12k Ohm
< TRD (5mm) - RM450 >
Coil to Dist - 7.75k Ohm
Cable (1) 4.20k Ohm
Cable (2) n/a
Cable (3) n/a
Cable (4) 8.40k Ohm
< ULTRA Silicon Power Plug Wire (7mm) Made in Japan - RM450 >
Coil to Dist - 0.99k Ohm
Cable (1) 1.98k Ohm
Cable (2) 1.98k Ohm
Cable (3) 1.98k Ohm
Cable (4) 1.98k Ohm
< SPLITFIRE TWINCORE (10mm??) - RM?? >
Coil to Dist - 0.35k Ohm
Cable (1) 0.35k Ohm
Cable (2) 0.45k Ohm
Cable (3) 0.28k Ohm
Cable (4) 0.39k Ohm
< HOTSOT Double Extruded Silicon Cable (8mm) Made in Australia - RM?? >
Coil to Dist - 4.55k Ohm
Cable (1) n/a
Cable (2) n/a
Cable (3) n/a
Cable (4) n/a
< NGK POWER CABLE (5mm) RM370>
Coil to Dist - 0.37k Ohm
Cable (1) 0.40k Ohm
Cable (2) 0.34k Ohm
Cable (3) 0.30k Ohm
Cable (4) 0.21k Ohm
Suprisingly, TRD cable has very close resistance value to stock cables, which mean its performance also very close to stock's, theoritically. ULTRA has very consistance resistance value from Cable (1) ~ (4), that allow it to delivery similar ignotion power to 4 piston. And, Splitfire Twincore has an unbeatable low resistance value - par in performance.
Please share your finding here.
(Those who are using TRD cable please don't shot me le
Coil to Dist - n/a
Cable (1) 5.16k Ohm
Cable (2) 5.90k Ohm
Cable (3) 7.50k Ohm
Cable (4) 8.12k Ohm
Cable (1) 4.20k Ohm
Cable (2) n/a
Cable (3) n/a
Cable (4) 8.40k Ohm
Cable (1) 1.98k Ohm
Cable (2) 1.98k Ohm
Cable (3) 1.98k Ohm
Cable (4) 1.98k Ohm
Cable (1) 0.35k Ohm
Cable (2) 0.45k Ohm
Cable (3) 0.28k Ohm
Cable (4) 0.39k Ohm
Cable (1) n/a
Cable (2) n/a
Cable (3) n/a
Cable (4) n/a
Cable (1) 0.40k Ohm
Cable (2) 0.34k Ohm
Cable (3) 0.30k Ohm
Cable (4) 0.21k Ohm
because my engine Eat engine oil
