saufeq
Hi, it that a problem to put different size tire Front (205 /40/R17) and rear (205/45/R17) ? Mine fwd
It’s terrible for you, because FWD understeers already. Wider rear tires just makes it even worse. Plus different sizes just gonna mess up the balance of the car.
what is your goal? Looks? Then do whatever you
If just to use temporary, then can. I have used 205/50R16 front and 215/45R17 rear, when in transition from 16" to 17" rims........lolThe goal is to change both tyres to 45 but due to tight budget I'll take 2 first.. also I worried about esc or speed sensor get damage
Mitsu VR, like I say temporary no problem. Lomg term you cannot rotate the tyres is another problem .....lolSounds like lotus car has 16f, 17r tires. Huhu
I dont think the sensors will get damage as they are designed to just measure and feedback data. If it detects any abnormality it will show up as error (warning light) but this does not mean the sensor got damage.The goal is to change both tyres to 45 but due to tight budget I'll take 2 first.. also I worried about esc or speed sensor get damage
I don't think they will be damaged but the ESC behaviour might be a bit different if provoked, not sure.The goal is to change both tyres to 45 but due to tight budget I'll take 2 first.. also I worried about esc or speed sensor get damage
why not getting a normal tyre like Achilles or Hankook... so that you can same size...
Hankook V2 mid range only, need V12Evo2 above.....Achilles I don't think suitable for me caused I'm kinda wild driver. Hankook v2 already try long last but does not grip much.. right now I'm using mc6. I like it. Perf/touring quite balance.. price too..
Achilles ATR sport it not that bad. Experienced it on a Suprima before, i believe its HP category.Yup in my opinion.. entry level is enough for daily driving..good traction.. or maybe can put different type like ps4 at front, mc6 or ecopia for better. Just opinion
MC6 should be better than ATR Sport, not below ATR Sport.Achilles ATR sport it not that bad. Experienced it on a Suprima before, i believe its HP category.
MC6 and Ecopia are tayar pergi pasar compared to PS4 and ATR Sport. Not saying its bad but its well below Achilles ATR sport.
I would go for VR2 suggestion by going for all new alternative brand of HP tires.
twin turbo
