Continental MC6
i supposed many tyres can now soon compete against the PS4, the one to watch are PS4 S competitors these days
What I know is prices will begin at RM350, which would mean the 16 inchers
unfortunately i don't have the price chart though
AVAILABLE SIZES MC6
Section Rim Size (inch) Load Index Speed Rating
205/45 16 87 W
205/40 17 84 W
245/40 17 95 W
205/45 17 88 W
215/45 17 91 W
225/45 17 94 W
235/45 17 97 W
245/45 17 99 W
215/50 17 95 W
225/50 17 98 W
215/55 17 94 W
225/55 17 101 W
255/35 18 94 Y
265/35 18 97 Y
225/40 18 92 Y
235/40 18 95 Y
215/45 18 93 Y
225/45 18 95 Y
235/45 18 98 Y
245/45 18 100 Y
225/50 18 95 W
235/50 18 101 W
235/55 18 104 Y
265/30 19 93 Y
275/30 19 96 Y
285/30 19 98 Y
245/40 19 98 Y
275/40 19 105 Y
245/45 19 102 Y
295/30 20 101 Y
245/35 20 95 Y
255/35 20 97 Y
275/35 20 102 Y
285/35 20 104 Y
295/35 20 105 Y
245/40 20 99 Y
265/40 20 104
For me since I'm not using 19' above, I don't look for PS4S & its competitors anymore. I only look for the best choices available in 17', maybe 18' max at best if I were to decide to upgrade.
PS4S is for elite already, comes in 19" and 20", even MC6 enter the higher market with 17" with a single 16" size....:smokin:
agreed, in a way even "entry level" UHP tyres today provide plenty of performance for all weather road use as well as enthusiastic driving, so one need not go out of their way to get the best of the best these days.
Re: Mc6
Well, Asean made got preferential duty rate...:driver:
No more block pattern, follow F1A3 and PS4 thread pattern.....:biggrin:
Probably with MC6 the CPC6 won't make it here
F1A3, PS4, & CSC5/6 are all still similar straight cut more orderly looking tread pattern like before, unlike this new MC6 where the cut at the side seems a bit more random/organic like chunks of rubber chipping off, hence looks more like a truck tire going bald! :biggrin:
I hope we would still get CPC6 as I suspect that is still the better UHP than this MC6.
Re: Mc6
Yah! the others the cuts are more fine, unlike MC6, bigger cuts.
Well, got to wait and see if CPC6 turns up, but if made in EU, can be rather expensive.....lol
Here it is guys, my thoughts on the new Max Contact 6 tyres as posted here and the link to the review:
http://www.zerotohundred.com/2017/first-impressions-continental-max-contact-mc6-new-uhp-contender-3/
There's a new UHP candidate from Continental Tyre lately, and it's just not another Sport Contact sibling either. Yes you've heard, It's the new MC6. Short for Max Contact, The new MC series will not just replace older MC5, it takes on a new role in the world of Ultra High Performance tyres.
What's more, the MC6 now competes against Michelin's super duper PS4. Also, the MC6 supports wheel sizes ranging 16-20 inches in diameter.
MC6 New Features
Multifunctional Tread Design
The new radical tread pattern is a proud feature of the MC6 and is said to increase grip and handling level as well as contribute in reducing braking distance in both wet or dry conditions.
Adaptive Grip Compound
With engineering down to the molecular level, the MC6 has what Continental Tyre calls the MaxContact compound that contains adhesive polymers, which enables higher grip levels thanks to improved adaptation to various road surfaces.
Xtreme Force Construction
The entire tyre now benefits from higher stiffness through newly developed Xtreme-Force ply material, which reduces tyre flex thus provides better steering and car control. Ironically, this material retains flextibility at low speed to deliver a comfortable ride.
Stabiliser Bars
In between the tyre's grooves has what Continental Tyre call the Stabiliser bars, and there's about 50 of them in each tyre. These series of reinforcement bars are moulded in to the tyre, in between the grooves on the outer side to further strengthen the tyre during high speed maneuvers.
Wet Braking
On the pit lane at Sepang's south paddocks, a wet braking arena was set up. It consists of a dry acceleration zone, followed by a full wet braking zone, complete with water sprinklers that constantly saturate the area.
In this exercise:
  • 6 BMW 330e were deployed
  • First 3 BMW 330e wear new Continental MC6 Tyres
  • Remaining 3 BMW 330e are on previous MC5 tyres.
  • 2 runs on each car
  • Braking stats are measured via VBOX logger
MC6 330e
First up, the new MC6 equipped 330e. Under full acceleration on said course, the 330e yielded about 70km/h just before the braking zone. We are to apply the brakes only when the entire 330e crosses into the wet zone.
As anticipated, like any good tyre these days, the MC6 stopped beautifully without any significant deficits. If anything, stopping distance was better than I'd expected, probably just as impressive as the Goodyear Asymmetric 3
However, this is not taking into account Goodyear's test course being quite a bit longer in distance and higher speed, which was about 85km/h. Also, the Goodyear test was done on actual back straights of Sepang, whereas Continental did theirs on the Pit lane.
One could say it's the same tarmac but one can also argue the difference in rubber content that were laid by constant track use on the straights versus the pitlane. So the debate will never end. The only conclusion I can draw from here is the impressive stopping power demonstrated by the MC6 as a UHP entry.
But this was all before the impending comparison against the MC5.
http://www.zerotohundred.com/2017/review-goodyear-asymmetric-3-tyres-2017-first-drive/
MC5 330e
Launching the 330e in the same manner actually caused the rear wheels to spin and it wasn't a slight chirp like in the MC6. But an actual, audible and physical wheel spin which was quite surprising too, the 330e being rear wheel driven with 255 mm wide tyres. In this case the new MC6 easily clawed the tarmac better upon launch as expected, without drama.
Now comes braking. Despite noticing the wheelspin earlier, it hasn't really occurred to me that I was on the older MC5 tyres. Not until I applied the brakes. To my surprise, the 330e was virtually grip-less at the point of applying brakes. It felt like it took a lot more distance to stop. Even the ABS system was working overtime right till the end on this set of tyres. There is also less dive upon braking and instant suspension rebound like in the new MC6, further confirming the MC5 less enthusiastic wet braking performance.
Emergency Lane Change
Here comes the exciting part. In this course, drivers will get their cars up to speed, accelerating from starting point, about 300M before reaching a set of cones that forces an immediate lane change to the right. We are to clock and maintain at 80km/h throughout the exercise, and execute the lane change without braking
In this exercise:
  • 6 Mercedes C200 were deployed
  • First 3 Mercedes C200 wears new Continental MC6 Tyres
  • Remaining 3 Mercedes C200 are on previous MC5 tyres.
  • Cones in close proximity will be the obstacle here
  • Performance is judged based clearing the cones with the least drama.
MC5 Mercedes C200
This time, I start off with the MC5. Barrelling towards the obstacle at 80km/h, I was ready to make the lane change. As I see the opening on the right, I made the move and found the steering just didn't react as dynamically as expected.
I managed to clear the first set of cones on the first right swerve which required a subsequent left swerve. However, the MC5 tyres wouldn't have it and I then killed a series of cones as the car failed to respond to my immediate correction.
Executing an emergency lane change without first applying a touch of brakes can be challenging as there is no load on the front to prep the tyres for the evasive move. Which, in fact proved extremely difficult for the MC5 on both my tries.
I found:
  • The front tyres were reluctant to react immediately
  • Dead zone between steering movement and tyre reaction
  • There was a moment of tyre scrub as the front tyre collapses under sudden load
  • The rear tend to step out, creating a pendulum effect under steering correction
  • Severe steering correction to keep the car planted.
MC6 Mercedes C200
Yet another world of difference here with the new MC6 when compared to its MC5 predecessor. This includes both the initiation of first right swerve as well as the second left swerve.
Steering was direct and accurate in the MC6 equipped C200 which transformed the emergency lane change from 50-50 miss to literally a walk in the park. I was taken aback by the old MC5's initial irresponsive steering that had "you're in trouble now" written all over it. In the MC6, even at the second try with a slight increase in speed
The new tyres demonstrated superb steering response right from the moment of initiation. This aspect alone determines just how important steering feel can be especially during emergency maneuvers.
Track Driving
This is an aspect I wasn't able to conclude. Unfortunately I wasn't able to go out during the track driving segment as the slots were full for some reason. There were 5 GLA 200s for 10 journalists, with 2 journalists per car but I'd somehow became the 11th pax in this activity.
Nevertheless, the initial tests were sufficient to tell how far the MC6 has come within the MC range. I might just get to sample the MC6 in full in the near future just to see how it fares against the PS4 or the Eagle F1
Verdict
It's hard to tell how Continental's new entry fares against same category elites like Goodyear's Asymmetric 3 or Michelin's PS4 in a non controlled environment, furthermore my lack of track time means I can only judge based on the 2 test activities above.
But one thing's for sure, the MC6 certainly lives up to its AA rating and no doubt possess characteristics typically found in UHP tyres. If you need further encouragement to be certain of the MC6's credibility as a performance tyre, there you go.
MC6 Tyre Sizes
SectionRim Size (inch)Load IndexSpeed Rating
205/451687W
205/401784W
245/401795W
205/451788W
215/451791W
225/451794W
235/451797W
245/451799W
215/501795W
225/501798W
215/551794W
225/5517101W
255/351894Y
265/351897Y
225/401892Y
235/401895Y
215/451893Y
225/451895Y
235/451898Y
245/4518100Y
225/501895W
235/5018101W
235/5518104Y
265/301993Y
275/301996Y
285/301998Y
245/401998Y
275/4019105Y
245/4519102Y
295/3020101Y
245/352095Y
255/352097Y
275/3520102Y
285/3520104Y
295/3520105Y
245/402099Y
265/4020104Y
I can ignore this tire already coz it doesn't have any of my potential rear sizes now (245/40/18, 255/40/18, or 265/40/18). Quite odd coz normally at least should have 245/40/18 or 255/40/18.
They kept to the more popular sizes.....:driver:
225/50R17 was OEM on the older Accords, 245/45R18 OEM on BMW 5 series
Yes but 225/50/17 is not that common for UHP tires. I experienced this coz my previous front was this size. For example F1D5 & F1A2 did not have this size, only now with F1A3 this size becomes available. I find that 245/40/18 is a very common size, where almost all UHP tires have. Usually if they don't have 245/40/18 then they'd have 255/40/18 which is more rare. However strangely this MC6 doesn't have either of those sizes! Anyway I'm still skeptical too about this MC6, where it really sits among the others. Plus now I know how good is the V12 Evo 2 for its price, so makes me even less interested in this one. :biggrin:
That is what happened to bro. Suprafanatic, die hard Michelin fan. After he tried other tyres especially at a cheaper price, he now dare to try other tyres......lol:rofl:
Price not competitive enough to compete against the more well proven V12E2. :biggrin:
But Conti and Michelin have all the while been premium priced, but lately PS4 seems to be quite well priced....
Coz its made in Thailand. Anyway it's ok for Michelin to price their tires higher coz the market already accepted it as the one of the best if not the best premium tire brand. Conti also similar for their European made products, but not for this Malaysian MC6, hence people would rather opt for V12E2.
Even PS3 being Thai made was priced very high last time, even more than Asy2 from EU, but apparently now PS4 cheaper than Asy3.....lol
