AE111 Levin 275mm Brake Conversion
Ronaldo95163
Trinidad
Just trying to gather some information here guys.
I know the 258mm brakes from the AE111GT is a direct bolt on to the AE110.
But what about the 275mm brakes from the levin(I believe they came from the BZR model)...are they a direct fit as well?
Thanks
Just btw...this is the AE110 i'm referring to
you can try it..just bring to the right shop and they will fit it for you. Is the caliper 2 port or single ? Where did you bought it and how much ?
Haven't got them as yet. Today I found a set of 4 (front and rear, with calipers hubs etc) from a BZ touring AE101 wagon.
Took a picture of it as well.
Didn't get to take off the caliper to verify if it's single/dual pot though
Thing is when I laid my measuring tape across it it was ~280mm. :adore:
I believe these should fit as well since all the Macpherson strut AE brakes are basically interchangeable. (If these indeed are from a Macpherson setup. Which is why i'm confused. I can't seem to find a non super strut BZ touring with these large rotors. Someone please correct me if i'm wrong. I didn't get to see the front setup otherwise I would've known for sure)
Clearance is what i'm not sure about.
