Gear problem
Seremban
Hello, please I need your help. I am using Nissan cefiro A33, recently I observed that when driving the gear is running smoothly but when I applied break there is drawback like a force with sound when the gear is returning back. But during pick up time the gear is smooth. Please advice me on what to do. Thanks
Have you change your ATF fluid recently?
Check your auto-gear oil level and top up if it's not enough and use the correct ATF fluid recommended by Nissan.
A sudden jerk when it decelerates sounds like the gears in the GB are struggling to move. Either you're using the wrong oil, or it's over/under filled or your GB will need a overhaul soon since the Cefiro is a pretty old car.
