Braking issue
No idea, a little bit off topic but i have a 1.3 neo, could I just straight swap the engine for a 1.6 neo engine or mitsubishi engine? Or will I need to swap other things to
Sent from my SM-G935F using Tapatalk
Might as well find the problem first. Unless major, then only thing of swap.....lol
yup, diagnose the problem first.
either brake issue, clutch issue. Full repair/replacement is cheaper than engine swap ?
anyway is your call base on mechanics advice. :smokin:
Okay I will resolve the problem before thinking about engine swap
Is straight swap easy or will I need to replace fuel lines, electrics and everything? Want more power haha
If swap engine then everything needs to be swap, including wire harness, ECU and so on. Is like what we do here when we swap those half cut engines.
