Braking issue
lukel95
GB birmigham
Hi guys, recently if i full lock to the left and then brake whilst reversing my brakes make a very loud sort of trumpet sound, any ideas?
Sent from my SM-G935F using Tapatalk
Do you left your car in the rain or just recently washed it? If yes, it's just the sound of your disc/brake pad squeaking, which is normal.
Yeah it mainly does it after being in wet conditions or after washing so I did think today that could be the cause
Luke, brake sound happened every times ?
Drum brakes at the rear or fully disc brake.
If disc rust then no need full turn will have sound also......:smokin:
or your brake pad no more already.. some cars pad finish uneven.. if new brake pad the rust after water splash (as above mentioned)..
Also when I brake coming to a stop sometimes I'll hear a scratching noise and if going down hill, the noise will sometimes continue after braking, would that be a sticking caliper?
Could be sand trapped in between, or your pads near finish the indicator touching the disc?:smokin:
agree with uncleVR.
I not sure about trumpet sound, my wild guess. Might be caliper release too slow.
Ahh and handbrake too. When release it make noise too but not trumpet-ing when move the car.
Happened to my old car.
