top overhaul
is it recommended to buy gasket set from oversea, like ebay USA?
complete set.
I saw even china also selling such stuff but don't wish to risk it.
I notice the gasket also come in thickness, is it the thicker the better?
complete set.
If buy from overseas, what happens if it does not fit?
Gasket thicker to lessen the compression, like for people who bolt on turbo to their NA, which have a higher compression, so using a thicker gasket will reduce the compression.
complete set.
Don buy from US, too far away. Uncle VR correct too, not fit then another headache.
Careful with ebay pricing too....
I buy from ebay cheap stuff only, those that I can afford to loose in case not working....hhahahhaha
And also look for those that include shipping.....:driver:
you still drive E3 with much problem awaiting to solve ?
you can check with ZTH marketplace seller for ISC.
yeah.. don't know how to describe, reliable engine or my luck..
still can drive, still can boost but don't know how long.
overhaul is just a prevention as I have never done it before, hopefully it will stop all whatever leaks.
is ISC universal? able to direct me to the light?
sorry, I'm also an uncle.
I don't know much, just know how to drive..
noted.
no doubt, the price is very tempting.
USD 300-400 for a brand new turbo.
provided made in usa.
check with seller DDT.
some got 1G or 2G model.
You say your turbo dying, what symptoms? Mine was blowing white smoke. Turbo shaft loose oil leak into exhaust......lol
to be frank, I don't know what are the tell sign or symptoms of a dying turbo.
if you recall correctly, I can't boost well in the past 2 years.
turn out to be a faulty ecu, each time when I tried to, the whole engine will choke.
only recent, a change of rechipped ecu, then the boost is normal at 1 bar.
of course, with a new toy, I tried to boost as much as I could..
excited like a small boy although we are old. :driver:
the boost has dropped over time, from 1 bar to 0.5 and over the last weekend, it went back to 0.8 after sending to the mechanic.
my mechanic was telling me that it just a matter of time before the turbo bid bye bye to me.
the cause is probably the faulty ecu, when the spooling starts, it was stopped.
of course, still can play around.
since I am thinking of doing an overhaul, I was exploring to see what is a good replacement.
ok.. the painful part has come:
Price as quoted:
Full overhaul Gasket set (metal 2.0mm) x 01 RM480.00
Piston Rings Set (std) x 01 RM145
Conrod Bearing Set x 01 RM130
Head Skimming x 01 RM60
Engine oil 10/50 HYO + Oil filter x 01, RM205
Gear Oil EP90 x 01 RM60
Full overhaul workmanship x 01 RM500
Total: RM1580
Optional:
Turbo repair + upgrade to 20G RM1300 exclude GST
******any necessary repair to be announced....******
ECU wiring checking - FOC
ISC repair, the mechanic will mod to eliminate the leak, helping the timing to be higher.
Turbo is mechanical, I don't think anything wrong if not boosting. Usually boost control is the wastegate or if you have any leaks.
My 2 cases. Waste gate spring broke, can only get 0 boost as all leak out, then vacuum hose broke, waste gate was shut tight, my boost went into 1.3 region. After repair back to standard 0.6 for VR..:driver:
Price as quoted:
Total: RM1580
Optional:
Piston rings damn cheap woh!
Not bad for the price...Why not overhaul n service turbo first...Run the engine then go for 20g..
yeah, that would be a cheaper alternative.
spend RM1.5k first, to do up the engine and leaks.
the turbo upgrade/repair, is just a tag along.
helps to save some penny amount on the labor.
repair of the turbo, cost like RM1.4k
while buying a new one, AVS TD05 20g, cost RM1.8k..
*sigh.. need to find money*
I notice initially, the understanding was only a top overhaul but based on his quotation, it has become a full overhaul.
he has help me to save cost by repairing the ISC, the clutch, flywheel. (*hopefully)
a metal gasket of 2.0mm, is quality.
free ecu wiring do up, my current is a mess, like bee hoon..
my current is a messy, like bee hoon..
Hide the wires!
:love:
