lukel95
What coilovers fit 2009 proton satria neo? Do only satria neo specific fit or can evo fit?
Sent from my SM-G935F using Tapatalk
Okay sweet cheers
I don't know, I know I can order them from mylasia but that's why I was wondering if you can get evo ones to fit because they will be easier to get hold ofAre you able to get the parts in GB?
Okay so if it fit those to the rear of the neo the rear ride height would be crazy low?u can fit coilover from first gen proton satria/compact or any from evo1,2,3 without much problem....
just the rear ride height need a bit of adjustment via the coilover....
because satria neo rear strut is longer than those satria/evo for about 1-2inch which u will be able to compensate with the adjustment from coilover unit....
on the side note....if u want to retain some degree of road comfort...opt for 5kg/mm front spring and 3kg/mm rear spring... (default most coilover spring would be 6kg/mm front+4kg/mm rear and higher up to 8kg/mm front+6kg/mm rear which is suited more for dedicated trackday/autoX users)
Okay will having evo ones mean I can't go as low or as high?no problem when u got coilover...means u can set the ride height anyway u like....
Okay thankyou mate, I want to go low:)u can go lower or exactly similar to stock ride height...
but if u want higher/lift kit/rally spec suspension, then u should look for proper rally/offroad suspension...![]()
Also do you know if there are any camber kits for the rear wheels available on the satria neo?Okay thankyou mate, I want to go low:)
Okay great thanks mate, any idea what Honda they fit on?well..locally we able to get our hands on this kind of camber kit arm... (blue D2 brand)
but may not be available to you.....i stumbled upon Honda FD2R rear camber kit which looks too similar to the proton neo... maybe...u can check with your local supplier for comparison/measurement
Ohh haha that will be why I never heard of one I'll look them up and look into the d2 set, cheers matehonda civic FD2r (jdm)
oh dangg...i forgot....not available officially in uk coz u guy got FN2R and FK2R models
Is it possible to get a short shifter for the neo to?honda civic FD2r (jdm)
cross breed of godzilla and jz engine
