Fuel Pump
biao
perak / ipoh
Hi mates,
On yesterday my trek fuel pump not function already. now need to find replacement.
any suggest?
walbro? AVS?
how much Liter PER Hour ?
normally we use Walbro but it'll be very noisy when weather is hot... about the specs, I really don't know. Just got it fixed at Ah Wah's.
why weather hot will very noisy?
i search on the market have Walbro, AVS & AEM brand? actually all this brand is good right?
Walbro is good and reliable.
When it's hot, the fuel tank has more gas vapor increasing the pressure in the fuel tank, therefore the pump tends to run noisier. It can be heard if you open the door from outside. On cold morning, it's okay.
nowadays, walbro got a lot of fakes.. from Taiwan or china..
I used walbro for a month and sold it off.. damn noisy
oic. means inside the car cant heard it.
you buy rm2xx?
Around there.
Should be rm200 or rm250 .
I feel new fuel pump is definitely better than an used.
A fuel pump can last you for many many good years.
Just remember, always maintain at least half tank when you are away.
can try DW or AEM but AEM might overheat if fuel not kept at least at 1/4 filled. DW i heard very reliable.
Around there.
thanks. ya i plan buy the new 1
don't believe him..
you look at his nick, an original fuel pump will be suffice for his needs?
he only runs rich, ron100..:driver:
Bro., all stock, so no need upgrade pump lah! In fact, at the beginning I had problem with the pump. It stops pumping at time, so my mechanic thought pump konk, so he find used one. Fit it time it runs, but off and on it stops. Finally found an ECU guy he say your pump no problem, your ECU failing. Not long later the ECU really konk, then change ECU. The pump still the same one for 15 years dy.
I did try one tank Ron100, like no difference, so back to 95, not even 97.....hhahhahahah
you change original? how bout the cost?
My mechanic bought used one, but still using old one. Bought one still keeping as spare in tool box, not sure after so many years can still use or not.....lol:biggrin:
