Do you carry a spare tyre?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Total voters
I did not have problem with my tyres too for quite a few years but still keep the spare in the car......lol
I agree with Ixeo & Tom...running on 35 series or lower in Msia will get u in trouble one day...I had my days :bawling:
Really zero air and could not feel it?? Should have noticeably bad traction already, wiggling sensation coz it's at the rear. Or you're using RFT?
Anyway that's why I'd never use such waffer thin tires even if I have the budget. :biggrin:
unfortunately there weren't anything obvious at all. Especially it being rear.
Nope non RFT as well.
I've seen a number of cars on 20s and up with a flat traveling on the road with the driver completely clueless. I probably saved a couple of them from a trouble
Mine 45 series is max limit.....:driver:
For me, 10cm sidewall height is the minimum, will not go lower than that. So for example I'm still fine if to use 255/40 but not 195/50 or 215/45.
Yeah, many are not even sensitive to normal thick tires having very low pressure, so if such waffer thin tires then no surprise if also even more unaware. I also sometimes try to warn people if I saw them running on very low pressures already on the road, but some maybe think I'm some abd guy trying to trick and rob them or something and just keep going as normal. :biggrin:
