Best oil for B-series engine
MrSpoon
Terengganu
Salam n hi to all hondarian@ZTH..
Anyone can suggest me for the best oil for B-Series engine?
Currently using B18Cr engine on my EK 4 door.
Usually use my car for long distance trip (700km) every 2 weeks.
Already tried Shell HX5 15w-40...good performance at first but kinda quick to burn.
Also ENEOS 15w-40...performance drop drastically,so i think its bad.
So,anyone who use B-Series engine can suggest any best oil?
Thanks in advance.
Shell HX5 15w-40 is a mineral oil. Even Eneos 15w-40 is mineral oil. Probably you should try any branded Semi Synthetic 10w-40. If you are burning oil, your engine may have problem.
Thanks in advance.
How about thinner 5w-30 fully synthethic viscosity oil? I am sure Honda recommended the 30 weight oils for their B series performance engines.
yeah..i think my engine got minor problem because i can detect small amount of oil leaking..thinking about going for top overhaul soon. :banghead:
but before that, i need to change oil first for my next trip.. (cargo from sarawak > klang)
so,30 weight is not recommended for now yes?because of that minor problem?
vr2turbo,mind to share what is the good brand of 10w-40 semi synthetic oil? :tongue:
MrSpoon,
U may try MOTUL either Semi-synth , Fully-synth or Easter.
Nothing special about this brand just a good quality product.
Thanks in advance.
go find Lucas Oil fully syn series (race oil)...much better than motul 300v
There aren't really any best oil for specific engines. Just suitable thin/thickness for the condition of the engine. As so, mineral grade were never meant to be performance promising.
Leakage and piston ring worn are common contributor for oil reduction.
So what is the current mileage? Has the engine ever gone through any built/overhaul ?
Try Moty's M111 5W-40 engine oil. Daily usage with city driving and highways within Klang Valley, sometimes I clock 1000km+ on my FD2R within a week and the oil level is still alright. Asked my mechanic/tuner about this engine oil and once he told me it's highly recommended by J'S Racing, I straight away changed my gear oil to this brand as well.
Like bro. Ken mentioned, play with the viscosity. If you rebuild the engine by all means can use 30 weight, but since worn no need FS oil. SS will be good enough. For me if SS, a good brand will do. Mobil, Pennzoil, Petronas etc...many brands:driver:
i use caltex 10w40 on my B16A...which i use for track days. very happy with it.
recommended to me by a friend of mine who runs his B18CR on track too... and he has high comp 82mm forged pistons with skunk2 cams running abour 200whp
recommended to him by his mechanic whos cars has been on MSS podiums about 3 times.
minimal engine oil loss during track days.
current mileage is 534445..as long as i know,this car never gone through any overhaul yet..
n of course the mileage is include original engine run before i installed this engine 2 years back..
where can i get this oil?i will add this to my prefered oil list..
i will add this to my list as well..
Get something easily available rather then go hunting for it.......
Yeah..already check with the moty's malaysia. Its hard to get at my place unless by postage,so i dont bother to use it,maybe next time.
Gonna check with caltex today tho.
---------- Post added at 04:29 PM ---------- 6 hour anti-bump limit - Previous post was at 04:27 PM ----------
Pentagon Enterprise, Jln Sungei Besi. Look for Chris.
I'll looking forward to this on my next service,but not now because kinda hard to get it here (sarawak)..when my car at johor next month,hoping will be easier to get it.
Wow! you are a traveler. Location Terengganu, Car in JB, you are is Sarawak......lol:driver:
Your B series mileage is more than half a million km already, and still going strong :top:. Mine has only done 87,000km. I'm using Shell full synthetic 5W40. So far the performance is good and oil level is also ok.
b-series yg stock elok pakai ss ja.sekarang pkai eneos 10w-40 kt b18cr..ok ja buat masa sekarang..cuma nak kongsi pengalaman..penah pakai hyrax 10w-40 dan motul turbolight.hyrax paling xtahan,asyik hilang walaupun xbuka vtec..so,hyrax mmg x rekemen..motul hilang time buka vtec ja..kadang2 mnyak enjin ni ikut kesesuaian enjin masing2 juga(orang la cakap). nk minta pendapat ttg platinum oil,ok ka x??ada spa2 pnah try?
87k km is like new, if oil level go down serious dy.....:driver:
Looking to try other brands of engine oil? :)
