Original NGK Spark Plug
congorwg
Rawang
Item(s): Original NGK Spark Plugs
Package includes: Spark Plugs
Price: Depends on model
Warranty:Nil
Dealing method: Courier only
Contact method/details: 013-3411159(SMS / WhatsApp / Wechat / call will be attend after 6pm), Email : [email protected], PM or post here
Age of item:Brand New
Item(s) conditions: New
Shipping duration : 2-5 working days after confirmation of payment
Picture:https://lh3.googleusercontent.com/-C2inEyjcY4Q/Uzthik0hm-I/AAAAAAAAF-Y/St1sZt0Csow/w958-h719-no/20140402_073845.jpg
--> NGK SPARK PLUGS size]
The World Leader in spark plug technology - NGK Spark Plugs. They offer the highest quality products for virtually every vehicle application. Furthermore they supply OEM spark plug to most of the car manufacturer to ensure their engine perform in perfect and stable condition.
Type of Spark Plug:
NGK Laser Iridium Series Plugs
Laser Iridium® spark plugs provide superior ignitability and long service life. Smallest tip diameter available Iridium / Platinum surfaces ensure slow wear rate providing stable idle, superior anti fouling, improved fuel efficiency and lower emissions
Laser welded Iridium center electrode tip
Platinum disc welded to backside of ground electrode provides long life
Trivalent Metal Plating for superior anti-corrosion and anti-seizing
Faster starts and quicker acceleration
Better fuel economy and lower emissions
Best OEM Iridium spark plug available
Original Equipment Manufacturer approved design
NGK Iridium IX Series Plugs
The Spark Plug Serious Enthusiasts Rely On
Designed specifically for the performance enthusiast. Iridium IX® offers extreme ignitability, improved throttle response and superior anti fouling
* Fine Iridium tip ensures high durability and a consistently stable spark
* Iridium alloy has extremely high melting point, perfect for today’s high-tech, high-performance engines
* Trivalent Metal Plating - superior anti-corrosion and anti-seizing properties
* Outstanding acceleration, high fuel efficiency and durability
* Ultimate design, technology and performance
NGK Laser Platinium Spark Plugs
Laser Platinum® spark plugs provide high ignitability and longer service life. Dual platinum surfaces ensure slow wear rate providing stable idle, superior anti fouling, improved fuel efficiency and lower emissions.
* Laser welded Platinum center electrode tip
* Platinum disc welded to backside of ground electrode provides long life
* Trivalent Metal Plating provides superior anti-corrosion and anti-seizing properties
* Faster starts and quicker acceleration
* Better fuel economy and lower emissions
* Best Platinum spark plug available
* Original Equipment Manufacturer approved design
NGK G-Power Platinium Spark Plugs
Improved Fuel Efficiency, Lower Emissions, Quicker Starts.
* Fine platinum tip reduces required voltage
* Extremely durable under high heat
* Best platinum spark plug at an economical cost
How to differentiate Original NGK Spark Plugs and Imitation Sparks:
https://lh4.googleusercontent.com/-XE_62ZYKoy8/Uzo-_hltZxI/AAAAAAAAF0E/YOVRkrzR7wI/w694-h378-no/photo7.jpg
Example of problem cause be excessive period of use:
For more information about NGK Spark Plug:
[YOUTUBE]https://youtu.be/wFkCVNhXMF0[/YOUTUBE]
***Please email me or leave comment for the Spark Plugs part number or just tell me your vehicle model, so that i can check the price for you****
Do you have BP7ES plugs?
How much is it?
Hi, thanks for enquiry.
so sorry i didn't carry standard spark plug, but you may consider below 2 type higher range of spark plug:
1) NGK G-Power Platinum Spark Plug - BPR6EGP
2) NGK Iridium IX Spark Plug - BPR7EIX
Price pmed, kindly check your inbox.
Thanks.
