Car cannot start
Merdeka evening wen to midvalley. After hangout going back time car canot start. Car can crank as normal. But cant start.Battery is still OK.all electrical can be normal function. Open rear seat check fuel pump, pull out the outlet hose from fuel pump. On ignition, fuel spray out. Check infront fuel gt naik or not. Found fuel naik after on ignition. And the pressure aso high. Check for api. Place a wire at spark plug cabel and ground it. Found api. I have no idea wt course can make the car cannot start. Any idea y the car cannot start????:confused::confused::confused::bawling::bawling:
What car? Immobilizer? Ignition coil?
Fuel check at front is before injectors? Sure any fuel going into combustion chamber?
if spark plug cable no api means crank sensor...
but your case got api....i think try check cam sensor
i encountered before, its fuel pump. but you have troubleshoot there already....can share what went wrong actually.?
fuel pump faulty it wouldnt send fuel splashing if we remove fuel hose at fuel rail/injector rail...
(that kind of method i'm using on waja and many other car to if suspect fuel pump not working)
