Car Air-cond Compressor
Car Shops and Services
sgwangacc,
ok, thanx, will drop by at your outlet after raya break.
Replaced the Perodua Kancil's air-cond compressor
Bro,
Quote for me... My Kancil compressor got a sound kruk krak kruk krak and not cold...
Thanks
Air-cond compressor on an Audi A4
The car vehicle needs to be raised up in order to dismantle the air-cond parts effectively
Flushed out the dirts from the air-cond system before installing the new compressor
Problem: Air-cond is totally not cold when engine starts
Solution: Replacing an air-cond compressor on a Peugeot 308
This Chevrolet Aveo was on its second visit and decided to replace the faulty part - air-cond compressor
This old air-cond compressor - Chevrolet Aveo was found leaked
Just dismantled the old air-cond compressor from this Chevrolet Aveo
New unit of air-cond compressor - Chevrolet Aveo
Replacing air-cond compressor of Perodua Viva
http://i1114.photobucket.com/albums/k534/sgwangacc/air%20cond%20parts/air-cond_service_compressor_viva_perodua_sgwangacc-2_zpshsez29au.jpg
Replacing Air-Cond Compressor @ Mazda 5
Dissemble front bumper
Dismantle the air-cond compressor from bottom
TaDa!~ This is the Mazda 5 Air-Cond Compressor
It's time to assemble back the compressor. Nice & Tight
Don't forget to change the Receiver Drier (It works as Filter in A/C system)
CONTACT / VISIT UShttp://www.sgwangacc.com.my/contacts-sgwang for servicing your Mazda.
Full Air Cond Service & Replacing Cooling Coil @ Peugeot 408 Turbo
Get started to dismantle entire dashboard & taking out the Cooling Coil :nod:
Dismantle elements of the Cooling Coil Set (Heater - Coil - Blower Motor)
Restore the Cooling Coil Set -- Clean Housing , Blower Motor Set, Heater & Replace New Cooling Coil , Expansion Valve
It's time to assemble back Cooling Coil Set & Dashboard components
Miss Peugeot 408 Turbo is back to serve its owner with cooler cabin!~
Footage: Peugeot 408 Turbo Compressor is changed as well
CONTACT / VISIT UShttp://www.sgwangacc.com.my/contacts-sgwang for servicing your Peugeot 408 Turbo.
