Alpine Cda-9886 w PXA-h100
HeLLonEarTH
kuching
Dear fellow ZTH,
I have a question here. Is anyone familiar with these 2 combo? CDA-9886 + PXA-H100? Here is the situation. I have already done my settings in the multeq > sound field adjustments and saved it in preset 1, 2, 3. Each preset is for different music genre (mostly adjust its T.A and xover settings) and i always use preset 1 as a default. But the irritating part is, whenever i switch off the car, and when i turn the car on. The multeq settings rolls back to factory settings and i have to always recall it by pressing A-Processor recall 1,2,3. The settings dosent go away. It stays in its memory but doesnt stay at the last settings that i use. I have checked back my wirings on both deck and imprint. They are correct (according to the manual). Did i miss something here or is it suppose to be that way because its irritating to always recall the settings whenever i turn my car back on.
Thanks :banghead:
It sounds like you might have a connection problem. It's not supposed to do that.
It only stores the saved memory but whenever i switch the car on again. i have to recall. I tried putting the PXA-H100 (+) at acc on and rem out. Same thing. Should i try to put at +12v wire? :banghead:
Uh.. the PXA supposed to have one +, one earth, one acc and one remote out. How on earth did you connect it with Acc and Rem only?
It comes in 2 wires. One yellow one black. And at the yellow end, it splits. I connect the (batt +) to 12v headunit. Or am i doing it wrong? In the headunit book, it says to connect PXA-H100 to the REM headunit. But in PXA-H100 it says connect to 12v battery. :banghead:
