My suspension dilemma
gbsaint
Hi guys and hear my story out.*
Need your opinion. After a bunch of other upgrades i decided it was time to mod my suspension.*
My car is a proton inspira btw.*
Initially 10 months back i started to change the spring to proton R3 springs. It was great, good compromise between comfort and handling. (level was 3 fingers loose back and 2 1/2 finger front)*
After a while my driving improved and started to feel that the suspension could not handle fast corners.*
Thats when i change my absorber to proride sport (yellow). It was good but i was disappointed when it did not give any more drop. But on the upshot handling has been increased.*
Then sebab gatal tangan, decided to change to adjustable (ISC, used 10 months) in view of:
-wanter to drop the car more (3 finger tight rear and 2 finger tight front)*
-better handling and control
After i changed i noticed that although the car felt planted taking high speed corners,the car was damn bouncy, especially at the cyberjaya-putrajaya-puchong highway.*
My question is what should i do next, i already tried changing the springs rate from stock, 8k front and 6k rear to 6k front and 4k progressive rear.*
Any sifu willing to give input.*
Tqvm*
https://www.zerotohundred.com/forums/attachments/541116.vB[https://forum]https://www.zerotohundred.com/forums/attachments/541115.vB
U want good handling then comfort definitely will be compromise. You CANT have best of both worlds.
What you should do is decide on what you actually want?
U want handling then forget comfort, U want comfort, forget handling.
Tqvm*
View attachment 541116[https://forum]View attachment 541115
STOCK OEM suspension one is the best and comfort handling !
You should first get a proper shock absorber rebound rate, it determine how the fast your spring is compressed and released.
Test drive lancer/inspira fitted with f-tuned or RCS.. and see which one you prefer.
it's possible to have good handling with lots of compliancy on the road - it's the valving that matters.
if you do not want high spring rates, tune the handling with thicker anti roll bars.
Best of both world, look for rcs.
To reiterate on what the others have said. Once you go the adjustables route and use stiffer 6K/8K springs, be prepared to sacrifice a significant amount of comfort. The better brands have more pliant absorbers but there's still bumpiness on poorly surfaced roads. Not bone jarring but nevertheless bumpy.
Tulah gatal tangan sangat :tongue:
If your opt for those custom made suspensions like RCS / Titan, be sure to have extra moolah in hand. Depending on your needs (or wants), it will definitely cost you.
Also, be prepared to visit them often for tuning until you find the 'perfect' setup.
I had my suspension upgraded, so for comfort just close one eye. Well, I need something to control the VR power........hahhahahhaha:rofl:
Hi guys thanks for all your replies.
The setup i want i a slightly harder setup than my springs and shocks combo but will give a good drop and good performance balance.
I don't mind the suspension is hard, the problem is that it is bouncy on certain roads.
I thought of titan and rcs but both got 2 big cons.
-Titan > the lynspira group did a group buy on titan, but then they all had weird noises from the shocks. Also there are some members complains of bottoming out.
-RCS >> expensive, but that's not the biggest problem, the problem is service is rm350 per piece every 20k/1 year.
There is no way i'm gonna pay rm1.5 k just to service my shocks every year.
I'm thinking that maybe my used adjustable needs some servicing. What do u guys think??
Ya but rcs valving is very specialized.
Nway titan was actually my first aim. Good review (from other car clubs) , most say maintain some comfort with good balance of sporty movement. Pluse service rm100 per piece.
But then when inspira came along got issues.
Damn.
Do you have a big budget? Eibach prokit springs + Koni FSD absorbers. I'm not sure if they may for Lancer/Inspira or not though. Koni is a 2 stage absorber that's pressure dependent. The harder you press it (hard/fast corners) the stiffer it becomes. But when you're just cruising along normal roads it's soft and pleasant. Eibachs usually do a good job of lowering cars.
Alternatively I'd recommend BC Racing / AR Racing coilovers. Bodyshift lets you lower height without compressing springs (I'm not sure if your ISC can do this or not) so it doesn't affect ride quality. HLSH allows you to adjust dampening to suite your driving style and you can DIY it instead of revalving.
OR consider FTuned. Their absorbers are monotubes, their HLSH is adjustable which you can DIY to suite your driving style and at the same time the fellas behind the brand are ex-Proton Lotus R3 engineers who developed the R3 suspension. You can't go wrong with that sort of expertise.
Thanks for the idea, Koni + elbach. Will look forward to that xD
suspension set up is very tricky. going too low or too hard will will make the car handle alot worst (street use) then intended. the lowest you should go is when your lower arms are perfectly horizontal any lower you will need to add in a RCA. As for the bounce, like izo mentioned body shift will work well in lowering the ride without compressing springs. whats your current spring rates? absorber stifness must go in hand with spring rates. With all this factor in, this is why i like custom made set up. u may wanna look at ur current set up and playaround with the settings.
'Comfort' or the 'level of acceptable comfort' can be subjective. One man's meat can be another's poison. One fella says it's comfortable while another says his back about to break. :stickyman:
Go participate in TTs. Ride in other people's car & find out what your own level of acceptable comfort is. Tbh, I wished I did that before I made the jump. :smokin:
