NewBie to Perdana V6
spawn_net
Perdana V6 by far the BEST BUILD proton model intern of build quality accept for safety features.. hihi
Neways.. I bought a V6 2007 model. superb condition and all is well for until now after two years of using.. WHITE SMOKE!! arghhhhhh :banghead:
Asked around what should be done.. most say Top Overhaul and cost around 3k original parts.
So I have a buddy use to be a Perdana KAKI till he sold off his car. Recommended me tukar the engine..
Base on findings 3 best model to fit;
1. Eterna RS TT
2. 6A13TT
3. Evo III
Just wanna know what the Sifu of Perdana think looking at aspect of cost, reliability, availability of spare parts and maintenance cost.
how much can I get a difference by just changing gearbox to manual.
Top overhaul including timing belt cost under rm2k with Japanese branded parts.
1. Eterna RS TT
2. 6A13TT
3. Evo III
well built?
still ok, look at the impact of full speed on the rear of perdana..
hit by a toyota vellfire..
Engine, i say go for Evo 3.
I wanted it badly, provided price is good.
Manual or auto, i would go for manual.
always have been on manual, *real man uses 3 pedals* haha
2k?? Shop name n place?
---------- Post added at 04:31 PM ---------- 6 hour anti-bump limit - Previous post was at 04:29 PM ----------
well built?
Wahh bro that impact consider ok...
Imagine other models of Proton.. I think your engine fall off on the road.
I have had;
1. Saga (Mega-valve)
2. Wira
3. Waja
4. Now v6...
Proton should give me an award.. hahaha
If you are going turbo route, by all means transplant the engine, but if not, better you top overhaul.....:biggrin:
If top overhaul, buy your own parts and ask your trusted mechanic to do it, if you know what parts and brands you want. This way you can save quite a bit 10-20% on cost of parts.
wah top overhaul rm3k ah?
u got rm20k in hand? by all means go for evo3.
if not just overhaul it.
1.japan top overhaul kit RM150
2.japan full overhaul kit RM300.
3.timing belt set DAYCO RM350
4.spark plugs RM360 - iridiums
5.water pump Rm150-200
workmanship for the above>
RM800-1k. (full overhaul)
top overhaul RM400-600.
**includes item 3,4,5.
Bro, I think you typed wrongly,
Dayco timing belt set (EU/US) RM240.
Gates timing belt set (Japan) RM280
Proton timing belt set RM560
Japan Cherry top set RM330. Proton top set RM7xx.
Water pump (generic) RM95
Water pump (Proton) RM960
Denso Platinum spark plug RM38 X 6= RM228
it was sooo long ago since I did my engine rebuild, cant remember the price though just an estimation.
WOW 20K for EVO 3?? :banghead:
I have a 10k budget for the car....
6A13TT not legal on Perdana because it requires modification of the engine mounting.
halfcut rm13k
SS exhaust & intercooler pipings + samco RM2k
replace wear & tear parts RM2-3k depending on how critical are the parts need to be replaced include
respraying engine bay, engine oil & gearbox oil.
wiring & engine installation - Rm700-800.
the $$ balance is just for standby.
if u bought a lemon halfcut the costs will increase.
---------- Post added at 03:36 PM ---------- 6 hour anti-bump limit - Previous post was at 03:34 PM ----------
with your budget I suggest u just overhaul your engine.
I have had;
2. Wira
3. Waja
4. Now v6...
U do know engine falling out is the safety feature right.
halfcut rm13k
Thanks Bro.. Really Helped a lot..
maybe I just throw my Auto and move to Manual..
For the Standard V6..
What's the best Gear box?
Any specific model?
Can the standard V6 be upgraded by after market parts?
just sharing what i find on 4g63t in mudah..
http://www.mudah.my/Enjin+VR4+4G63T+extra+1+car+running+condition-33018803.htm
http://www.mudah.my/4g63T+lancer+evo3+engine+complete-32975566.htm
but located too far away, don't feel safe remitting so much money and no delivery..
Any specific model?
since u have rm10k to spare, keep rm5k for the engine & another rm5k for your gearbox just incase it dies.
for manual tranny on v6, u could opt for code 232(shorter ratio, clutch plate is 8.5") or 312(longer ratio, suitable for v6tt clutch plate is 9")
make sure its complete
1.gearbox
2.gear lever complete with cable
3.3 pedals, or 2 pedals enough (brake & clutch), some shops only provide the clutch pedal only, then u gotta cut your brake rubber pedal.
4.upper & lower clutch pump
5.clutch & flywheel
above could costs u rm4.5-5.5k
there are only minor upgrades for v6,
1.custom extractor - costs rm800-1k
2.crank pulley
3.cam pulley
4.aluminium radiator
Also can swap in MIVEC head, ECU, hydraulic lifters, PnP...
wanted to get mivec v6 head for my v6tt but the costs is equivalent to selling my v6tt engine & transplanting an evo 3 engine.
in the end sold off the car. :sleep:
