Alternator versus Battery
bro, belts are not pussies, doesn't mean tighter the better
too tight might end up "putus"
yes brother. tighten the belt. will looking that belt dressing. tq.
in normal cases, is it the belt can self tighten when we revving? OR becoz it was not enough tight?
New belts are softer so they grip better. As they are in the engine and always hot they tent to harden and wear too. So even if initially they are tighten they do wear and loosen with use.
Yup, tighten also but with some flex. Too tight can break...
a belt that is too tight will cause premature wear on the bearings and the belt it self.
Noted siffuu!! Thank You..
