Fault code P0170 Airtrek
Mobay
I have been getting a P0170 code on my Airtrek. The check engine light triggers this code, but then the check engine light is on sometimes and off at other times.
Anybody having similar problems or can shed any light on this situation?
Thanks in advance.
Hehe.. just noticed Greg2k8 is using my Airtrek photo for his avatar? kekekeke...
http://www.zerotohundred.com/newforums/image.php?u=148025&dateline=1362956918
http://helpforcars.net/obd_codes/p0170_mitsubishi.html
Possible causes
- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow (MAF) sensor
- Incorrect Positive Crankcase Ventilation (PCV) hose connection
Tech notes
Dirty air filter, air filter housing or Mass Air Flow (MAF) sensor, or faulty MAF sensor are common causes for the P0170 code.
When is the code detected?
Fuel injection system does not operate properly or the amount of mixture ratio compensation is not correct
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Excessive Fuel Consumption
P0170 MITSUBISHI Description
With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The Engine Control Module (http://engine-codes.com/articles/ecm.php) calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the http://engine-codes.com/articles/ecm.php judges the condition as the fuel injection system malfunction and light up the Malfunction Indicator Light (MIL) (2 trip detection logic).
Read more: http://helpforcars.net/obd_codes/p0170_mitsubishi.html#ixzz2QvE2xF7o
Its Oxygen O2 Sensor Low Voltage errpr
