Nope.1st time there coz he can weld a/c pipes.im gonna go to another shop coz sounda a bit fishy bout it.
Then better get second opinion first.....
Then better get second opinion first.....![]()
Done.just replace coil & dat tabung thing.no water found.cost rm450.1st shop wanted rm8++.gila.welding also like shit everywhere.should use elctric or blue weld.he used normal fire weld.had to pay rm100.
Next goin find ficd to stabilize rpm on/off ac.now ac off rpm at 2.5k. Ac on at 1.5k. Didnt have ficd yet
Guess wat, sumtimes my car died.like not enough fuel supply.just adjust my fuel regulator.goin to see tonite if it works or other prob start appearing
That means coil leaking. Condenser usually will last a long time. The tabung thing should be the receiver drier and normally have to be changed when air con is serviced as it act as a filter.
So first mechanic wanted you to change condenser also...![]()
hi there sifus,
I'm just wondering , if I have the budget what do you recommend for my 4g93, with 280 JUN cams, valve springs, titanium retainers , CAI , evo3 tb, 4.8 final ratio, full lock lsd and other engine internals are stock for tracking purposes. What do you recommend ? Haltech Sprint 500or E-manage Blue/Ultimate ? pros and cons please ?
Thank you..
can please anyone help me? currently i cant remove boost cut from my emanage im using emanage blue + 3 bar maf sensor + tps on l2 engine 3 cylinder turbocharged...in the setting i try to clamp up to 3 volts boost cut limiter setting but still got boost cut....pening to already...previously i use safc 5 button only and i use fish bone to hack signal from maf sensor and i can boost up my car up to 2.0 bar (actually more than 2.0bar i think coz my boost meter is up to 2.0 bar only)
