Braking, yes more in front but the rear locks easier. If rear bald more easy to skid.....my car no abs ok....hahhahahahhaa![]()
I also no ABS ma
Rear drum got ah?
Rear drum got ah?
I also no ABS maRear drum got ah?
It is not possible to wear out only 2 tyres, unless you didn't rotate the tyres. So yeah, padan muka kau and change all 4 tyres.
Actually I do understand why people don't rotate. My father says it's cheaper to change 2 at a time rather than all 4.
Now when I think about it, is it more cost effective to change 2 at a time or rotate which possibly makes the tyres last longer?
It will ALWAYS be cheaper to change 2 at a time rather than all 4. Cause.. you're paying for 2 rather than 4.
But, if you rotate, good and even tyre wear, all 4 tyres will be in good condition, and can last longer. I used my PS3 for ~50k km. That's with rotation. I rotate every ~15k km give or take.
"cost effective" la.. I didn't say cheaper. If rotating can last longer and really properly utilize the tyre then that's cost effective enough for me.
Question : Would you rotate a directional pattern tyre even if it means mounting it reverse?
You did say cheaper, then you said cost effective
Front to back, back to front, will mount reverse meh? Only if you do a cross rotating that occurs right. Then got to remove tyre and re-mount.
By right should have even wear on the tyre if everything is normal, for a street car.
Actually got rotate but one time only, when fit new to the rear you rotate the rear to the front mah!..haha
Cost effective or not, both have pros and cons. Most rotate because front wear shoulder and rear wear center. As I told bro. SF if front and rear wear is good why pay for rotation. Most shop charge even to rotate, then if balancing out, you need to balance and quite many I know do alignment also. Like most say last 50k km, means at least rotate 4 times. 2 tyre change you already save 4 times rotation and balancing RM.
Cost of changing tyre is not cheaper, but paying extra like rotation cost more. Change two at a time is cheaper but got to pay twice so is the same cost.
Did mention many times already the pros and cons.
It is more to the safety aspect for me.
4 tyre change you rotate until all 4 tyres bald. Period when 4 tyres bald, is danger period. If change 2 at a time, at any time you will still have two tyres with thread pattern....
---------- Post added at 04:15 PM ---------- 6 hour anti-bump limit - Previous post was at 04:13 PM ----------
If both sides wear inside, or both side wear outside, like bro. ixeo mention, remove tyre, re-mount them, then cross left to right, so the direction still points forward...![]()
Previously :
F = Kumho KU36 205/50/15
R = Neuton NT6000 195/55/15
Good corner entry, but waggy tail.
Now switched other way round. Massive understeer, tail steady.
Also, NT6000 in front noisy as hell.
This argument again?
Knnccbbq. Change all 4 when 1 or 2 is worn.
Enough of story.
Bro. Ken, Where you get the Neuton NT6000, never seen before?
Anyway, should use same size for both front and rear then don't have the problem. Some more different tyre brand and model also. KU36 is extreme some more....![]()
Am so sorry it's NT5000. Ahah let say ima on trial & error mode.
).....Its...
