Knocking/Pinging - Really bad or harmless?
Yes, mostly experience it when fuel up with shell 97. but i do experience it on mobil 1 fuel as well. it's on low rev when i wot there's slight knock on 3k rpm then the sudden surge at 4k rpm. and this usually happen on a hot sunny day. on a cool day eg 24-26'c car is smooth as silk. Suzuki Swift Sport with just some minor mods such as intake and exhaust with emu.
i have knocking too, but when i drive with lpg, i have no any knocking with petrol... i doupt about distributor, i just bought ignition plugs and plug cables.
Just pumped Caltex RON95 ...so far no knocking even though run with duratec 272 cam :proud:
so the consensus is fuel from which company experiences the least knocking? :biggrin:
Cannot say as different people have different results even with the same make of vehicle. Best is to test them yourself and see which fuel suits your car.
I tried Shell old FS formula Ron97 and it did not suit my VR so I went back to my Esso/Mobil which is now Petron. Since running fine on this I rather not test with other fuel, but another main reason also I have two Petron stations near my home....:biggrin:
Dont expect to demolish knocking from ur blacktop. It requires ron100 as a standard
how do you even define 'knocking'?
sounds from the cylinder head? ignition misfiring as pre-detonation?
I have experience with knocking..
my previous b20 piston crack..
