Which brand gauge meter more cheap and nice look? of cause must can use d.
How many and type of gauges? Size of the gauges?
Cheap means how much? Ur budget?
The reason why ppl install gauges is to hv accurate reading of engine vitals, thus the gauges should be showing accurate reading and being durable. I would recommend decent ones, not those imitation.
No point seeing a real doctor, but eating fake pills, right?
Like Shadow Gauges and AutoGauge Gauges will be good enough? Cuz Defis are really too expensive to own
boost meter. size? got how many size?
i means cheap is original item but lower price. not imitation item.
budget RM200 is it ok?
---------- Post added at 02:44 PM ---------- 6 hour anti-bump limit - Previous post was at 02:43 PM ----------
Defi? why expensive? i saw many sell very cheap, just around 100.
Budget RM200 then can go for Autogauge. Is ori. Fake one forget it. (Autogauge also have fake if not wrong)
RM100 for Defi? U surely need to survey more on the original price of Defi meters.
That's why we mentioned not to buy fake.
If ori Autogauge brands can cost up to RM200+-, I don't see any logic that well known brand like Defi would cost any less than Autogauge.![]()
ya i know. in KL area where can get Autogauge this brand? got with stand?
i saw many type of gauge Defi sell very cheap.
Original Autoguage is around RM200-250. Yes even this brand got fake ones these days.
Defi is expensive cos you need the control unit. 1 single boost meter + controller will cost you at least RM1K already.
Mechanical boost meter from Apexi also has loads of fake ones. Buy original ones. It sud cost around RM450-550.
I am using original SARD, mechanical one. I bought it 6 years ago for Rm350.
Mechanical Boost Meter - vacuum pipe directly connect to the back of the guage. There's a nipple to connect the pipe. Only 2/3 wires for the meter light.
Electronic Boost Meter - vacuum pipe connects to a control unit that looks like a small matchbox. The matchbox unit will send signal to the meter via wire. Usually electronic meter has opening ceremony and can check peak boost level.
best bang for buck when it comes to gauges would be shadow gauges
if iam not mistaken price around rm300,slightly expensive than works gauge.but better though
How much per piece bro?
:wavey:
