Engine Decarbonizer
Recently took out my spark plug and saw my piston head being really really oily and blacked.
I wanna know if anyone can share the before and after of the piston heads by using the so called carbonizer.
Those that poured in, not those in did in workshop using machines.
Pump V power Racing then go highway for a constant run will clear quite a lot of carbon.....:driver:
used seafoam,the original carbonizer or whatever.
3/4 through the vacuum lines(1/2 trough iacv vacuum and the other half from the TB vacuum)
1/4 inside the petrol.
So the conclusion,it doesnt work at all.maybe going to use another cleaner and put inside the combustion chamber trough the spark plug.
I used a machine at workshop. They use this product call Restorer. My feedback is that, my kelisa more responsive than before. Obvious improvement.
Pump RM20 bucks is enough. No need full tank. Also drive outstation for a day and keep a constant high speed for the whole journey and that'll do wonders too
Even mixing with RON 95?
Can do it when Im cruising to TTA. :biggrin:
Yup, as mentioned by bro. Izso, constant or cruising speed have best air fuel ratio. Combustion better and more complete will burn off the carbon, but nothing beat taking out and scrap it off....:biggrin:
Pump full tank la...u have nth but $. Go TTA mah haha..must have the spirit! Vpower racing!!
Drive 90kmh all the way to TTA. Sure can clean a bit. Usually at 2-3k rpm that's when the engine is most efficient.
I go TTA as visitor ah!!! :bawling:
Say carbon right, I saw I have but the engine has been quite responsive lately wor. Hmm
After blast out, even better, smoother engine drive. My wife Chery, always town drive day in and out, then after outstation drive she will mention engine so much smoother....:driver:
The other day I also drive in city only. Dunno why suddenly it became very responsive.
Where to get V power lah. Idk which Shell got.
Not sure if this is updated list.....
http://s03.static-shell.com/content/dam/shell-new/local/country/mys/downloads/pdf/shell-stations-mys-offering-v-power-racing-may2013.pdf
Manjalara statin got. Make sure u pump V-Power Racing, red colour nozzle. The green one is v power biasa
Engine felt responsive, so didnt bother with it, yet. Soon, gonna pump it after did major service.
Sent from my Lumia 925 using Tapatalk.
how much that it cost?wheres the shop location
Is at Michelin Manjalara. Is located near the Manjalara Jogging park. Corner shop. Just say some altis guy in kepong recommend. They will know :rofl:
Your cruising speed to TTA was 190km/h...that's quite "slow" to consider as cruising LOL! :rofl:
Yup, totally no regret if pump V-Power Racing. Really worth it but then if pocket not deep. Heartache a bit. :laugh:
