Hard Engine Break In Method Worked Wonder
upontheriversky
hi, i just want to share the result of hard engine break-in on my car which some of us may have read over the internet. It sounds controversial as compared to the traditional method of slow drive for first 1000km,
I decided to do hard engine break-in as recommended by motoman, i was convinced by the explanation and evidence provided thus i proceeded.(Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power)
recently i did compression and leak down test at N1 racing, sunway and the result was excellent. i didnt think of taking photo proof and detailed recording since i only wanted to check the status of the engine, so i only did rough and general recording for personal reference. i only thought of sharing it days after i have done the tests, otherwise i would have prepared proper recordings with photos
Compression test result:
i got an average of 180 PSI across all 3 cylinders (kelisa 1.0)
in general, results may be interpreted as below:
135 PSI and above indicates excellent compression,
below 100-120 PSI means bad,
below 85 PSI is extremely bad (severe engine mechanical problem)
but most important is to have almost same readings across all cylinders, less than 15% variation of pressures are acceptable
references to the above are below:
http://www.gregsengine.com/cylinder-compression-testing.html
http://easyautodiagnostics.com/ford/compression/2.3L/engine_compression_test_2.php
based on the above guide, the engine excelled the compression test which underwent hard break in method.
Leak Down Test result:
all were below 5% leak. But human error (mistakes in reading meter) may happened, therefore to be safe, i will say that im very sure that the leaks for all cylinders were below 10%, this is because i did not look carefully, just needed to know that the engine is ok
leak down test result interpretation:
1. Less than 5% - You either did something wrong or have one hell of a nice tight engine.
2. 5% to 10% - Great to good. You should have no worries.
3. 10% to 20% - Your motor may still run ok, but it isn't at it's best. Parts may be starting to wear out....keep an eye on it and test it more regularly.
4. 20% to 30% - It may be (and probably is) time for a rebuild.
5. Greater than 30% - You have some major engine issues that need to be addressed.
reference:
Compression and Leak-Down Testing - DSM Forums
Conclusion:
the engine compression was superb, i needed the compression to be 135 PSI to excel and i got 180 PSI. They were way beyond the minimum baseline of being "excellent".
therefore, judging from the excellent compression, i can safely say that it is also possible that all cylinders were below 5% leak in leak down test, otherwise it may be hard to achieve 180 PSI if the leaks were high
the engine was overhauled and broken in on july 2011, and it ran both tests above in april 2014, means after 2 years 9 months, the engine is still tight.
Although, since i did not do testing for traditional breaking in method for side by side comparison, it is immature to conclude that hard break-in is better than the traditional.
But one thing for sure is hard breaking-in the engine will give you promising results and there is no harm in trying it, this is the main reason i posted this topic, to remove doubts on engine hard break-in method
My engine never makan oil till today, although to say that my engine performed better than those being traditionally broken-in are baseless as i have no proof of that.
knowing that hard break in method worked wonder is enough for me :)
Credit goes to mr. motoman for his daring ideas and ballsy statements, and to N1 racing, sunway for providing the tests.
N1racing - Malaysia automotive and car parts and accessories supplies.
hope this benefits :)
Technical Articles at Greg's Engine & Machine
reference:
Conclusion:
Hard breaking in doesn't sound controversial to me. In fact, the other way around hahaha.
I've never believed in slow-and-steady breaking in.
Good job proving that hard-break-ins won't kill the engine!
