hi everyone,
pac_jb
hi im a newbie here, to all sifus, im driving perdana evo 3, one month ago , i just changed the head gasket and the o ring, but yesterday after i reach jb from seremban, i noticed the the gasket sealer melted and black oil leaked, i never boost on the highway, was just cruising 100 - 120kmh , can anyone let me know what can be the problem , and its evo 3 standard engine. thx
Welcome to ZTH.....:driver:
You mean Rocker cover rubber gasket? The sealant just to complete the sealing effect in case the rubber does not do the job properly.
If sealant melts then wrong sealant being used. The rubber gasket is original? Normally if original the seal is pretty good.
Does the Evo3 have a half moon rubber seal at the side? Is it leaking from there?
yes the rocker cover rubber gasket, yes its leaking from the half moon & at front of the rocker cover but the back of the cover looks fine, could it be because i never stop to cool down the engine ,when travelling from seremban to jb
need your mechanic to open the rocker cover again, scrape off all the sealant & apply it again, must use 300 degrees Celsius type not cap ayam ones.
Sending the car tommorow to re do the gasket. Will update once done , thx for the input
Check whether he change the half moon rubber gasket too. It will also harden with time and use.
Tighten with even pressure all round...
Hi bros, I already done my gasket, and everything was going perfectly till yesterday, now my car cannot boost and when on 1st and 2nd gear , I have to rev more than usual, to move the car, any Idea what can cause this problem. Thx
Just now, on the highway from , able to boost, but now 1st gear cannot boost at all, 2nd, 3rd and 4th is normal but engine but whenever I try to boost feel like the engine is rough . Dunno its the sensor or leaking or because of clog. Bros any idea. Thx
I had this problem before but mine is all gears. Mine because waste gate was opened
