Headunit for satria neo
brorishi
Hey guys... I know there is a similar thread to mine... But my issue is slightly different...
Anyways, I want to buy a new Hu... Can someone recommend me one which is plug and play for neo? Or can someone explain to me how to know if it's plug and play?... I also want to keep my steering controls...
Plug and play normally means the replacement can be fitted without any other mod.
But as far as newer cars are concerned nowadays the audio HU is incorporated into the dashboard design. If replacing the HU you will need to get the aftermarket interface to make it look the same as your original but not too sure of the Neo.
As for steering control some units have an additional set of wires to hook up to your original control. You will have to ask the shop which models have it
Yea neo can change quite easily... I don't even need to get any 1 or 2din casings... As it will fit just fine... I just need a huge without any wire cutting... Thats all... I don't mind about steering controls if the hu has its own remote...
Most after market units I think you need to mod the wiring as the plug and socket at the rear will be different
Hmmm.. Okay.. Because someone told me that neo uses iso harness (dunno what It means) and a certain pioneer headunit fits plug and play
Like you mentioned certain so not all. Some I think uses an adapter if not mistaken, so can considered plug and play too...
