kancil l2s
Harlo... need some advise...
getting a l2s soon.
1. 2"piping enough?? I plant to change to 2.2" izzit better??
2. std l2s turbo n td04-09/rhf4 how much diff??
3. L2s std turbo is single/2 fin turbine?? Td0409 2 fin??
4. Can std l2s do wastegate n downpipe??
totally new on turbo.. last time used to be na modification.
thx....
1. 2" pipe is enough since everything is stock
2. diff in what? if power, td04-09 is very good for street setup since boost kick @ before 4k rpm. rhf4 u need to mod ex housing in order to use.
3. l2s stock turbo single fin. td04-09 twin. rhf4 also twin fin.
4. depends on ur budget. but it wont give u more power. maybe just slight quicker response.
I mean the different inlet diameter airfilter turbo btw std l2s n td0409. Many use tdo409 should be gd response for l2s.. thx anyway..
td04 inlet from air filter and outlet to the intercooler also slightly bigger, hv to find replacement the ori intake and the steel pipe.. there still a way to use back ori air box la.. but normally ppl juz ikat steel mesh or juz chg to open pod
if ur kancil is a daily drive car, better get open pod. if its a weekend drive car, u can use steel mesh..
