Evo 1 to 10 Turbo Specs
stutzedward
Evo Stock Turbo Specs
Evolution 1
p/n = 49168-01450
Turbo = TDO5H-16G-7
Nozzle Area (cm2) = 7
TD05H turbine = Inconel (steel alloy)
Compressor = Aluminium
Inducer = 48.3mm
Exducer = 68mm
Evolution 2
p/n = 49168-01460
Turbo = TDO5H-16G-7
Inducer = 48.3mm
Exducer = 68mm
Evolution 3
p/n = 49178-01470
Turbo = TD05H-16G6-7
Inducer = 48.3mm
Exducer = 68mm
Reverse rotation turbos and twin sroll turbine housing from EVO4.
Evolution 4
p/n = 49178-01510
Turbo = TD05HR-16G6-9T
Nozzle Area (cm2) = 9
TD05HR turbine = Inconel (steel alloy)
Compressor 16G6 = Aluminium
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = twin flapper
Evolution 5
p/n = 49178-01520 (GSR)
Turbo = TD05HR-16G6-10.5T (GSR)
Turbo = TD05HRA-16G6-10.5T (RS)
Nozzle Area (cm2) = 10.5
TD05HR turbine = GSR Inconel (steel alloy)
TD05HRA turbine = RS Titanium alloy
Inducer = 48.3mm
Exducer = 68mm
Evolution 6
p/n = 49178-01550 (GSR)
Turbo = TD05HRA-16G6-10.5T (RS/RS2)
TD05HR turbine = GSR - Inconel (steel alloy)
Inducer = 48.3mm
Exducer = 68mm
Evolution 6.5 : Tommi Makinen Edition
p/n = 49178-01560 (RS2)
Turbo = TD05RA-15GK2-10.5T (GSR)
Turbo = TD05HRA-16G6-10.5T (RS/RS2) (Note: OZ TME)
TD05HRA turbine = Titanium alloy for both RS/RS2/GSR!
Inducer = 48.3mm
Exducer = 68mm
Compressor 15GK2 = Aluminium
Inducer = 49.3mm
Exducer = 65mm
Evolution 7
p/n = 49178-01570 (GSR)
p/n = 49178-01580 (RS)
Turbo = TD05HR-16G6-9.8T (GSR)
Turbo = TD05HRA-16G6-9.8T (RS/RS2)
Nozzle Area (cm2) = 9.8
TD05HRA turbine = RS/RS2 = Titanium alloy
Inducer = 48.3mm
Exducer = 68mm
Evolution 7 GTA
Turbo = TD05-15GK2-9.0T
Nozzle Area (cm2) = 9.0
TD05 Turbine = Inconel (steel alloy)
Inducer = 49.3mm
Exducer = 65mm
Evolution 8
p/n = 49378-01520 (GSR)
p/n = 49378-01540 (ADM EVO8 single flapper)
Turbo = TD05HR-16G6-9.8T (GSR / USDM / ADM)
Turbo = TD05HRA-16G6-9.8T (RS/RS2 & NZDM)
TD05HR turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy),
TD05HRA turbine = RS Titanium alloy.
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = twin flapper USDM
Evolution 8MR aka "8.5"
p/n = 49378-1560 (TD05HR-16G6-10.5T)
GSR = TD05HR-16G6-10.5T or TD05HRA-16G6-10.5T (Ti Alloy option)
RS = 6MT:TD05HRA-16G6-10.5T or 5MT:TD05HRA-16G6-9.8T
Nozzle Area (cm2) = 10.5 or 9.8 (RS-5speed)
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = single flapper
Evolution 9
p/n = 49378-01570 (GSR)
p/n = 49378-01571 (RS)
Turbo = TD05HRA-16G6mC-10.5T (RS)
TD05HR turbine GSR = Inconel (steel alloy),
TD05HRA turbine RS = Titanium alloy
Compressor 16G6 = Aluminium (GSR)
Inducer = 48.3mm
Exducer = 68mm
Compressor 16G6mC = Magnesium (RS)
Inducer = 48.3mm
Exducer = 68mm
Back to "normal" rotation turbos from EVOX.
Evolution X
p/n = 49378-01610
Turbo = TD05HA-152G6-12T (GSR)
Nozzle Area (cm2) = 12
TD05HA turbine = Titanium alloy
Compressor 152G6 = Aluminium
Inducer = ?
Exducer = ?
NOTE: TD05H & TD05HR & TD05HRA turbine wheel all models
Inducer = 56mm
Exducer = 49.2mm
All Evo 4-8 Turbos are twin scroll designs meaning that the engines exhaust is divided into two channels. As the engine exhausts in pulses.. its supposed to result in quicker spooling. From the Evo 4 onwards, the Turbo spins in the opposite direction, i.e. Anticlockwise (hence the R in the turbo name). The Titanium Alumnide alloy used in the RS/RS2 and some GSRS (factory option) has less inertia and thus spins up around 500 rpm sooner. These Titanium turbos can be indentified by the A in their name.
James got damn good trade with the e9 turbo~Edward . How abt ur e7 turbo ? Spooling fast?
I don't know what to compare with. Never really driven other treks with 05. But after hooking up the downpipe, makes a great deal of difference. So those with bigger turbos, pls get the downpipe. My sincere advice.
Mitsubishi OEM Turbo Specifications
Flow Rates @ 15psi:
TDO4-9B-6CM2 265 CFM
TDO5-12A-8CM2 320 CFM
TDO4-13G-5CM2 360 CFM
TEO4-13C-6CM2 360 CFM
TDO4L-13G-6CM2 360 CFM
TDO4L-15C-8.5CM2 390 CFM
TDO5H-14B-6CM2 405 CFM
TDO5H-14G-8CM2 465 CFM
TDO5H-16G-7CM2 505 CFM
TDO5H-16G-10CM2 505 CFM
TDO6-17C-8CM2 550 CFM
TDO6H-20G-14CM2 650 CFM
TDO7S-25G-17CM2 850 CFM
TFO8L-30V-18CM2 1200 CFM
Max Output:
TD05-14B (stock 1st gen) 275-300hp @ 21 psi
TD05-16G (small) 345-365hp @ 22 psi
TD06-16G (large) 365-385hp @ 22 psi
TD06-20G 430-450hp @ 22 psi
T25 (stock 2nd gen) 235-250hp @ ?? psi
T3 (super 60)/T2.5 hybrid 265-280hp @ ?? psi
T3 (super 60)/T2.8 hybrid 270-320hp @ ?? psi
Evolution 1
Turbo = TDO5H–16G-7
Exhaust turbine = Inconel (steel alloy)
Compressor = Aluminium, 60mm wide
Evolution 2
Turbo = TDO5H–16G-7
Evolution 3
Turbo = TD05H–16G6-7
Compressor = Aluminium, 68mm wide
small correction... more info Mitsubishi OEM turbo specifications (including flow rates) - evolutionm.net
