6a12tt-rs.perdana v6
are u using metal gasket? if no your head will pecah soon. i guess the boost reading is incorrect.
should be max 0.8-1bar
maybe meter faulty, try swapping with your friends one 1st.
---------- Post added at 01:28 PM ---------- 6 hour anti-bump limit - Previous post was at 01:28 PM ----------
or maybe the vacuum hose salah cucuk lubang, try to get 2nd opinion from another mech.
1st istall it was at 0 bar....the blue hose 1 is boost meter hose....
Siri bercakap dengan HP sendiri...
Heheheheh.....budged already lariii laaa....
What is difrent 0 bar and -0.5 bar reading at boost meter?wich 1 is true 0 bar or -0.5 bar?
Right or not this boost meter reading?
At idle should be -0.5 to -0.6. At 0 means normal use like NA.
For your boost what have you set it up to? Like mine is still standard at 0.6, so maximum throttle will stay at 0.6.
Maybe meter is not wrong but your boost is high, so be careful, better check...
Bro, I salute you as you dare to go beyond the limits even without metal gasket but if I were you I'll get a metal gasket installed before going for high boost though(if your boost meter is accurate) as I wouldn't want to risk a blown gasket or worst case scenario blown engine in the middle of the road lol.
I dont know my car was like that.....I dont do any things just install boost meter, 2.5 inch pipe intercooler, blitz sus power air flow, 3 inch from front to rear exzos pipe no middle muffler & nissan silvia s15 exzos 3inch thats all......I think my car was read at 0.5 bar - 0.8 bar only..... :(
Then better double back to your mech if u have any and get it checked out otherwise send to dyno to be safe. Or u can install an external waste gate where u can set the boost level to either low or high. Running high boost on the road without metal gasket is like waiting for the time bomb to go off.
My car make a sound like a wastegate...Its sound like whoooooossshhhh when I step on gas paddle.......then when boost meter at 0.6 he make sound like 'berdengung'.....why aaa..... :(
looks like there is a leak somewhere....i experienced the same thing as u but just cant remember how i rectified the problem.
if not mistaken something bocor at the exhaust system
So check exzos system from front to rear?
yup.....jack up your car, go underneath, start your engine & get someone to rev your engine while u hear where the sound is coming from.
---------- Post added at 09:05 PM ---------- 6 hour anti-bump limit - Previous post was at 09:04 PM ----------
How to setting this bov blitz??
try the screw at the top.
The screw must be short or long?
Ok I will cek that exzos system......
Yours got 2 screws? Normally the one which a locking nut....:driver:
That 1 laa with nut lock....that screw can adjust long and short.....I adjust that long....its that for thighten right?
