Wifi enabled car
idnawse
perak
Just wanna share my new and low cost diy.. :itsme:
Bought this mini portable 3g/4g wifi router and plan to fix permanently inside my cockpit
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-prn1/q71/s720x720/540723_10151718067069350_383770971_n.jpg
Next process, dismantle
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-ash3/q74/s720x720/543796_10151718067229350_360145650_n.jpg
Make a panel cover for coin drawer slot. Later will cut to make hole for USB port
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash4/q87/s720x720/1003345_10151718067104350_1901099561_n.jpg
Marking and cut the router housing.
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash3/q72/s720x720/1012257_10151718067204350_1350977885_n.jpg
https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash3/q75/s720x720/534171_10151718067239350_1126012454_n.jpg
Done stage 1
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-prn1/q83/s720x720/1012049_10151718067319350_1260113357_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-prn1/q86/s720x720/547665_10151718067489350_1248519825_n.jpg
Checking the router after the fitting process .. green lit mean 3G is connected
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-prn2/q80/s720x720/970135_10151718067529350_429678007_n.jpg
Use this USB car adaptor for power source (5V 1A output)
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash3/q86/s720x720/945945_10151718067639350_1444323456_n.jpg
Dismantling and rewiring process
https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-prn1/q85/s720x720/553969_10151718067759350_1236690604_n.jpg
Placing the power source inside the router. Extend the antenna (small white and black wire) for better TX/RX
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-ash4/q80/s720x720/1004651_10151718067829350_1658952957_n.jpg
Done..stage 2
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-ash3/q84/s720x720/46401_10151718067859350_509116874_n.jpg
Fit inside the coin drawer and wiring. Done. Just plug in USB broadband modem and enjoy wifi
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-ash3/q87/s720x720/562981_10151718067989350_541567142_n.jpg
Next plan will be transferring the status indicator using fibre optic cable coz the LED is very small and hard to relocate and solder.
Can the router handle the inconsistant power supply from the car?
Using in-car usb adaptor charger (use for charge tablet/handphone) board might not give problem coz it only use 5v 1000mA.
nice diy.
for led you could use a normal size 3mm or 5mm and parallel / replace the existing one.
if for 5v power indicator you need a 100ohm resistor serie to the led.
Ya, plan like that before, but looking the pcb layout, not enuff expert to re-solder on tiny2 area like dat. What i mean is indicator for router (power on, wifi status, connecting status) not power status from switch to router.
