Microtech tuning
Razor5932
Singapore
Hi.
I am running microtech lt10 ecu on my car. My setup is as follows.
Mivec 4g15 engine with td04 turbo, 440 injector, Walbro fuel pump
However, the tuning done previously caused some issues that I am facing. I get very unstable idle rpm. Occasionally my engine die off cos idle rpm too low. Once I rev. There is alot of black smoke.
My mivec cam was shut off cos my previous set up using gt28 blow my engine twice with mivec running. Can I check now that since I am using td04. Can microtech support mivec and prevent my engine from blown again? The horsepower from my this set up is disappointing. Need some advice pls.
Anywhere can intro a good tuner for microtech ecu?
Thanks.
not low idling, i think u r running rich during cold start/idling ..tat y alot black smoke
I know it's rich. Cos the tuner increase the fuel in the afr to mitigate the idle rpm fluctuation issue.
As microtech does not require the need for maf. Then how is the idle control solved during idle rpm?
Cos my car initially having frequent idle rpm fluctuations.
The throttle body, is there a screw that you adjust to prevent the throttle plate from closing tightly shut? Try adjust it a little to open the throttle plate a little to raise idle RPM.
Regarding LT10, it should work alright with your setup, just need a good tuner.
he tune using tps only?
i'm no expert on questioning on other people tuning work....
but maybe tune using MAP can give more stable result.....if not mistaken lt10s was capable of doing many things....maybe can consult other tuner nearby?
Tuy?n nhân viên gõ captcha online nh?n luong theo tu?n
V?i xu th? cu?c s?ng nang d?ng ngÃ*y nay, b?t c? ai cung có th? t? tin ki?m du?c vi?c lÃ*m. B?n dang lÃ* sinh viên, hay có nhi?u th?i gian rãnh r?i, mu?n ki?m thêm thu nh?p t? m?t công vi?c don gi?n. Gõ Capcha s? lÃ* m?t s? l?a ch?n dúng d?n cho b?n.
Yêu c?u :
- Có máy tÃ*nh k?t n?i Internet
- Có tÃ*i kho?n ATM d? nh?n luong
- Có th?i gian r?nh, d?c bi?t vÃ*o bu?i t?i.
- Nh?n biêt t?t các d?ng phông ch?, có kh? nang dánh máy nhanh vÃ* chÃ*nh xác - Có tÃ*nh kiên trì, nh?n n?i
Mô t? công vi?c:
- Gõ l?i các hình ?nh du?c load v? trên m?t ph?n m?m ho?c m?t trình duy?t.
VÃ* d?: trên mÃ*n hình hi?n ra ch? "ABCD" thì b?n gõ dúng l?i nhu v?y r?i enter d? hoÃ*n t?t mã Capcha dó. Tùy theo d? án mÃ* có thêm s?, phân bi?t ch? hoa ch? thu?ng.
Quy?n l?i:
- Ch? d?ng v? th?i gian vÃ* d?a di?m lÃ*m vi?c
- Luong du?c thanh toán toÃ*n b? qua tÃ*i kho?n ATM.
- Có co h?i thang ti?n trong công vi?c.
- Khi dã quen tay thì 50 ngÃ*n/ ngÃ*y lÃ* c?t m?c d? dÃ*ng d?t du?c, m?t tháng hoÃ*n toÃ*n có th? ki?m du?c t? 3-4 tri?u (n?u lÃ*m d? 8h m?t ngÃ*y)
... Chú ý ... D? nh?n du?c luong, nhân viên c?n hoÃ*n thÃ*nh ch? tiêu c?a d? án theo tu?n ho?c 4 tu?n. C? ý gõ b?y, b? qua tùy ti?n ho?c h?t th?i gian /1Cap quá nhi?u l?n s? b? thu h?i t?i kho?n
Hu?ng d?n dang ký lÃ*m vi?c:
-Truy c?p website: http://chovo.vn d? xem thông tin v? công vi?c nÃ*y vÃ* dang ký lÃ*m vi?c v?i các d? án nhé!
-Sau khi dang ký xong thì liên h? v?i mh qua YM! work0nljne d? dc c?p user lÃ*m vi?c.
M?i chi ti?t xin liên h? theo thông tin bên du?i, mình s? gi?i dáp t?n tình nh?ng th?c m?c c?a các b?n d? có th? nhanh chóng b?t tay vÃ*o công vi?c.
Qu?n lý: Mr Son
Yahoo: work0nljne O979 85 87 89
---------- Post added at 06:23 PM ---------- 6 hour anti-bump limit - Previous post was at 05:26 PM ----------
Yêu c?u :
Mô t? công vi?c:
Quy?n l?i:
Qu?n lý: Mr Son
---------- Post added at 06:26 PM ---------- 6 hour anti-bump limit - Previous post was at 06:23 PM ----------
Yêu c?u :
Mô t? công vi?c:
Quy?n l?i:
Qu?n lý: Mr Son
---------- Post added at 06:27 PM ---------- 6 hour anti-bump limit - Previous post was at 06:26 PM ----------
Yêu c?u :
Mô t? công vi?c:
Quy?n l?i:
Qu?n lý: Mr Son
