Urgent: AE101 Cluth problem
CountersteerSan
Johor
Urgent: AE101 Clutch problem
Dear all sifus, need some help again. So my mom just came back from Jusco 20 minutes ago and something happened to the clutch so she had to just leave the car in the middle of the road and walk back. When I went to see the car I realized that the clutch feels damm light when I step on it and it wont engage. In the end I manage to engage the clutch by jabbing it multiple times until the clutch pedal feels a bit hard to step on again and I drove the car home with only the first gear. When I reached home I still have to jab the clutch like 8-10 times before I can shift the gear from first to neutral. Any idea whats wrong with the car? For those who can, reply asap pls and thanks in advance.
Problem:
-Clutch pedal feels damm light when stepped on
-Clutch cannot be engaged, cannot shift gear.
-Need to repeatedly jab the clutch pedal until it feels abit hard again to shift.
-Car model AE101.
Re: Urgent: AE101 Clutch problem
Problem:
-Car model AE101.
Bro., Is it hydraulic clutch system? If yes, check fluid level, maybe got leak so clutch is light and cannot engage. If not, then probably pressure plate or clutch plate problem
Yeah, the mechanic said something like "clutch pump leaking" took him an hour or two to fix it and he charged Rm80 for it. Not sure if he changed the parts or just sealed it up as a temporary measure. Anyhow, thanks bro.
Eighty only, could be he just change the internal parts using repair kit. but sometime must be careful because if the pump wall is worn, the kit won't last long and will leak again...
had this problem before, changed the pump and everything worked fine. about the same price as u said. for me, the pump is located somewhere near the extractor, shaped like a size D battery, with a nipple to bleed out the air. check if yours is new or not.
At the engine will be the lower pump....
