Unbalanced ride height
DerrickEe
Hi guys, about 2-3 months ago, I have changed all 4 tyres and rims on my Perodua Viva, changed my front mount absorbers, and changed to aftermarket springs.
On the day it was installed, I noticed my ride height is unbalanced, as it is lower to my front right side. (3 finger gap from tyres to fender on the front left, 2 finger gap from tyres on the front right) So i asked the same foreman that installed everything on my car on the day itself, he said its normal because the springs are still soft and it will be ok after some time????
Weeks after installation, I noticed that my front right tyre is flatter than my other 3 tyres, until now.
Does anyone know what is the problem? Springs? Tyres? Front mount absorbers? Afraid of premature wear on my tyre if this problem isnt solved. Thank you in advance.
What absorbers and what springs?
Sport springs are shorter than your normal spring so it's probably just not seated properly on the absorber.
Check the air pressure of your tyres, then if still uneven height, check the absorber mounting on top. Maybe one side worn more then the other...
I am using Apexi Myvi springs,with stock perodua absorbers. Before installation I compared the springs to see the length,and the front two springs are indeed equal in length.
I noticed the slant in height right after installation of the brand new front mount absorbers,so I dont think the front mount absorbers are worn out.
I will check the tyre pressure this week.
In that case, check the spring mounting and if that is okay too, probably one spring tension is weaker
i also have the same problem. park my car on even and flat surface and check the car height. driver side are lower and the gap is about one inches (both front&rear) compared to d passenger side. saw older forum saying that it is normal, so i just ignore it. anyone can clarify or enlighten dis?
When new or old. If old, could be due to wear and tear. Driver side always with load....:driver:
that was also the main reason i opt for adjustable suspension when time came of changing absorber back then.....
can adjust each absorber to compensate....
my xperience,
last time my car seg also left hand side higher than right hand side almost 5mm.....ask mech.....they said normal.....somemore show me te others car also same.....coz our engine sit more to right side......after accident......i sent my car to toyota repair ctr.....come out .....both side same high......according to toyota.....they said my car chasis LARI oledi.....so they realign it...:nurse:
---------- Post added at 12:53 PM ---------- 6 hour anti-bump limit - Previous post was at 12:52 PM ----------
my xperience,
Actually my car also has this problem when I changed to KYB adjustable. I got it installed at Kakimotor cheras.
Front: Driver side is lower than passenger
Rear: Driver side is higher than passenger
Difference: between half to one finger width.
I have not checked the adjusted height as i dont have jack stands. I've called kakimotor to clarify this and they told me that this is very common in myvi. They have done a few myvi and all of them have unbalanced height once changed to adjustable. I really doubt it because by logic, if all 4 adjustable coilovers are manufactured with little defect, how can the height be different? The mounting point is fixed.
Well until now i have not done anything to it yet as it does not affect much but it must be rectified. Maybe will borrow jack stand from izso on 1st of June and measure/adjust :biggrin: moreover i can get more advice from you guys.
can u try measure it with the construction ruler. the ruler that have a bubble inside it...i don't know what its name..it happened to me also after changing to the ride height adjustable. then i measured it seems the car is balance. so i don't have to worried about it. hehe:biggrin:
Yours are adjustable so once the suspension settles in, can adjust the height accordingly...
lets say, bfo u install te adj. absor. on ur car......normally.......they oledi adjust te "spring holder" left n right same height......but......after u install.......left n right side not balance.....i think may be te absofber pressure r differ left n right......i use to hav this problem when i use local refurbish adjustable absor......not to mention here......but TITAN no such problem.......te way they inject gas is more professional...
---------- Post added at 08:34 PM ---------- 6 hour anti-bump limit - Previous post was at 08:31 PM ----------
it could be te spring rate differ.....wheres its manufacturing defect....
It has been 4-5 months now. Time to readjust abit hehe...wana lift up the front abit and lower the back a bit. It's currently in a diving position lol
