got semput semput with my evo engine
nasrulyusof
Anyone please help me...got pening kepala because my pomen already surrender. I got problem with my lancer Ck6A. I using evo 4 RS engine, but got semput-semput when tarik pickup.
All part was change but still semput-semput..
The parts was changed from old to new one is:
1. Air flow sensor
2. Coil Plug
3. Fuel ray
4. Fuel regulator
5. Spark plug Denso
6. Fuel pump 2jZ
7. Crank sensor
8. Throttle body
9. ECU
But my evo still semput-semput...arrgh...:banghead:
coil and plug in good condition, also try take my friend evo 4 coil n plug install into my engine, but still same problem. huh.:banghead:
already do dyno computer test but everything ok.
using after market bov brand SARD high pressure. but before this no problem. i dont think BOV..
My engine is standard stock, i use original evo 4 plug cable, i also think my cable plug maybe rosak, and i try to use my friend evo 4 plug cable, but still got same problem...
everything i try to change into my engine with my friend engine parts. his car is running condition. the parts i borrow from my friend and try to install into my engine is : airflow sensor, fuel ray, fuel regulator, injector, throttle body, plug cable, coil plug, fuel pump, crank sensor and ECU. For info, i can ram my engine from 1000rpm to 9000rpm without semput if not bergerak, if tarik pickup, my engine will semput-semput. I dont think my fuel filter got problem. but one thing i see at my car is, my rpm kadang-kandang stay at 1000rpm and kadang kadang at 1500rpm (idling time) after tarik pickup. not like throttle body rosak (rpm like high cam)
---------- Post added at 05:03 PM ---------- 6 hour anti-bump limit - Previous post was at 04:46 PM ----------
2 unit ECU i try to use. but still same problem. coil system still using JDM evo 4 standard.
check any vaccum/boost leak at all rubber hose and piping....
manatau if some vaccum hose loose/crack around the throttle body
normal boost for my engione is 0.6 bar. IF got leakage at some hose, piping or etc the boost reading will go higher. But for this problem my boost reading is normal.
i have no idea about the 2jz fuel pump. my pomen advise me to get the 2jz fuel pump. btw how to know which fuel pump most better for my car but please dont tell me the walbro one la...
yes, walbro bro...its only suitable for evo engines. no choice. try borrowing your fren's one 1st.
ya. buy a new one walbro.many evos engine or others engine used walbro lor for replacement.huhuh
The same problem on my car but already resolved. Changed to new Iridium spark plugs.
have a same prob b4, change walbro and fpr and injector, slowly tune the fpr and problem solve, fuel not enough when having load, free rev is without load on wheel not the same high rev with the load on wheel...
