Airtrek Turbo Gearbox
Poacher
Auckland, NZ
Hi Guys,
Just some advise. I am going to flush my gearbox soon. Is there any recommended good quality transmission oil to use and any additives? Also If i want to install a second trans cooler (and disconnect it from the radiator) what is the best location for this? Can it be put on the opposite side of the 1st trans cooler? I am running my aircon and a front mount so no room at the front really....
Also does someone have a how-to write up for increasing the line pressure on the transmission?
Thanks!
Never use additives. Original is sufficient. I know most car has ATF filter nut never change before tho.
i used Redline ATF oil for my first 20000km and Motul ATF oil for now.
Both served well.
Using Millers Oil SPIII ATF fr England now. Good with 5litre packs :-)
Diaqueen SPIII is good enuf too, but make sure u got the ori 1.
