Car shake when ever decelerate.
mrs88
Any 1 could help me out?
I had change a lot of things.
Fuel filter
Plug
Cable plug
Distributor cap
Rotor arm
Fuel regulator
ECU
The shake symptoms occurs mostly around d 2nd n 3rd gear in 1800 to 3000 rpm.
If car shaking should be road uneven, If engine shaking then different story bro. :biggrin:
Toyota corolla.its engine shaking.mostly around 2nd n 3rd gear.
Hop u guys can help me..pls.
engine mounting - car vibrating during idling
driveshaft - car vibrates during pick up.
your corolla which year & model?
injector dirty or fuel regulator need tuning perhaps?
tq..buddies
engine mtg change d.
drive shaft i oso replace 2 liao.
its does not vibrate when its being idle.
jus quiet enough though.
occur only when u r engaging in 2nd gear thru decelerate..or 3rd gear etc.
tq..buddies
i had this problem before.. it was the clutch. coz if in 2nd or 3rd it vibrates when foot is off accelerator. but when i press the clutch, vibration disappears.
i was thinking 2 test d injector by tomorrow.
perharps..
---------- Post added at 10:27 PM ---------- 6 hour anti-bump limit - Previous post was at 10:20 PM ----------
oic.so how u solve d problem.
did u replace d clutch set.
---------- Post added at 10:28 PM ---------- 6 hour anti-bump limit - Previous post was at 10:27 PM ----------
o..mine ride is a ae111 mt year 1996.
---------- Post added at 10:35 PM ---------- 6 hour anti-bump limit - Previous post was at 10:28 PM ----------
did u replace d clutch to solved it.tq
perharps..
in my case, yes.. clutch n pressure plate.. drive around with the mechanic before rectifying, play safe.. :nurse:
Fuel filter
Plug
Cable plug
Distributor cap
Rotor arm
Fuel regulator
ECU
To help us help you better, it'll be better if you could elaborate more on the issue.
Where do you think the vibration is coming from? Is it the Engine or is it the chassis (suspension, tyres, brakes). Does the steering wheel vibrate? if not, it's nothing to do with the driving wheels or the suspension. Are you able to post a video?
