Water leakage by the doors
maximum
Hi guys
I realized if I park my car under rain, recently water leaks inside on passenger side in front. Now the driver side is the same.
1- I've seen people suggesting changing the rubber, How much does it cost?
2- Maybe because of changing the speakers. I changed them like 2 years ago, only now it starts leaking.
3- I heard that the water can leak from inside the door, which for me it seems to be the case, so I need to open the door and check (by purring water on the door and testing where the water goes). Any idea how to open the door cover? Is there anything tricky or hard to reassemble?
-Max
did u install new speaker ?...mine happened after install the speaker....just cover the hole with the original cover....open the cover is just easy....at the door holder there is one screw....unscrew it and open the cover....and there are 2 screw that hold the cover...unscrew it and its ready to open...
Remove coin holder by unscrew it, pull it out but it's quite thight at first..theres another 2 screws ..unscrew them, then pull the door panel there are hold by clips
Open the door trim.sit inside the car n close the door.ask sumome to pour water on ur window,than u can clearly see where the water dripping from.if from speakers,cover the hole.I had d same problem.wat I did was,cover the whole speaker magnet wit sound proof and than screw it.if budget,wrap wit plastic
yup...
common issue with neo if u change the door speakers...
hahaha
mine leak too after changing speakers...
resolved it by applying soundproofing/those sticky black thingy around the speakers mount...
I thought i could fix it myself ... but after opening it up, no way. Went to an audio shop instead.
The water drainage is directly on top of the speaker hole. really silly.
PM me i can direct you to the audio shop i went. job well done. no more leaks.
u got picture?
hey i had a similar problem.
I think my floor got hole or something,
It's wet on the carpet but not through doors.
I checked. Even though like this, I don't even know how to tell SC.
maybe from aircon water
