Adding 2T as petrol additives...
Yesterday, pump in my 3rd tank, everything running well. Looks like I will continue using 2T with Ron 95 for my VR....
this is pretty usefull, from hardware shop
http://img7.imageshack.us/img7/2361/bottleu.jpg
ya lah... sohai put 2T into EX5 fuel tank... but the moron dun even know wats the good smell from EX5 that put 2t into fuel tank & makes lotsa smoke all the way.... ahhahaa:thefinger::thefinger::thefinger:
agreed, topic now 2t put in petrol, my fren ex5 smoked away them flies behind my house:banghead::banghead:
---------- Post added at 04:48 AM ---------- 6 hour anti-bump limit - Previous post was at 04:44 AM ----------
bro what sat we compile all the data regarding the ratio of 2t:petrol
letsay according to hp @ cc:idea:
I've just started to use Marvel Mystery Oil, 4 oz of it i mix with RM50 of 95 petrol (around 26 litres), this is my second round mixing it with MMO, the first round i feel no difference, the FC still same and the engine runs like normal, but in the second round i feel the engine runs smoother, and the acceleration become more responsive, and i'm quite sure the FC is better, my FC normally without any additive is 1:8 (city driving), but later when refueling i will recalculate to know whether there is a difference or not, i'm still guessing whether my ratio is correct or not, btw my question is, which one is better, using MMO or 2T? is it the same?
and which brand of 2T are you recommend to use as additive for car?
is this serious?
how about spark plug range? remain the same or needed to use some other range of spark plug?
Mine is 1:250 which is 200ml to 50 liter petrol. 200bhp 2.0 turbo.
My problem is, if pump Ron 95 cannot run. Have been using some octane booster for a few months already until lately tested with 2T....:driver:
---------- Post added at 03:51 PM ---------- 6 hour anti-bump limit - Previous post was at 03:51 PM ----------
is this serious?
Sparky no change.....
n want more thing...the mixture ratio...is it all the same? 1:400? 1:500? 1:600? or else depends on engine output etc...
been reading from 1st post but no definite answer...i would like to try becos so tempting about smoothness it offers...
Bro. can try less first like 1:1000, if not difference then 1:500 and so on.....
owh ok...will give a try 100ml for 40liter is that too much?
sorry for too many question...im policemen :P
No problem asking questions as this is a forum and we exchange info mah.....:driver:
That is 1:400, if you are scare that is too much, try 50ml first. If no feel then 100ml and so on.
I add 200ml to 50L immediately.....:rofl:
guess i goto repost this
Been testing
a quote from tht thread
"We now are over 130,000 miles on our test mules ( collectively) with no ill side effects. All positive. Dont forget this is really an old school "trick"...folks have been putting in Marvel Mystery Oil and 2 Stroke oil for decades.....what we did is fine tune it. Furthermore do not lose sight of the fact at a 500:1 ratio ( really 1oz to 5 gallons is more like 600:1) you have less 2 stroke oil than water/chemicals that came with your gasoline. So you cannot "hurt" or degrade anything....it is all good for long term.....The reason I call for the Marine 2 Stroke oil is it is designed for and the add packs are there for water cooled motors....lower combustion ratings and detergents we were looking for. Use it with confidence.
For you folks running E10....this is a must to off set the long term corrosives of the corn alcohol on your seals/gaskets/fuel rails......"
my fomula is very simple, rm50 put in 50ml, rm100 put in 100ml
and after this, im planing to change to TC-W3 oil, a lower class 2t then jaso-d, use for marine engine, as mention in the forum above, it got a better cleaning agent and its ashless
cleaner engine cleaner catalytic converter, why not i would say, i just replace my factory spark plug to better plug, and the factory plug is very clean
http://imageshack.us/a/img833/6857/20130204224214.jpg
MMO's application is similiar to 2T oil but MMO's abit more expensive. However, it's a proven methods in US.
on my 1st full thank now @ 50ml/rm50
cant really feel the difference
---------- Post added at 09:02 AM ---------- 6 hour anti-bump limit - Previous post was at 09:01 AM ----------
