.: Exhaust Modification Corner :.
another car jpj n police can 'cari makan' :wink:
---------- Post added at 03:18 PM ---------- 6 hour anti-bump limit - Previous post was at 03:13 PM ----------
btw, what's d purpose of getting ur exhaust done?
for performance or just wanna tell every1 ur car is coming?
Thanks D7Zul for the advice,
But my problem is that my catalylic converter is clogged (sumbat), no power, exhaust shattering on and noises
coming from the shaky exhaust, can you advice other options to overcome this problem other than changing a new catalylic converter?:confused:
oh.. u just need to take off the catcon & put a pipe there..
no need to 'kacau' the other muffler/bullet :wink:
But normally for the cat, they will replace with bullet, right?
depends on car.. i guess
for my levin ae101.. it has a cat & middle bullet & rear muffler..
but previous owner deleted cat.. sorry mother nature.. i'll plant more trees soon
:biggrin:
guys sorry for running off topic but what will happen to a car's performance if the exhaust is blocked with objects? e.g. stuck with cloth
mine got no cat, no mid bullet, straight pipe & muffler :biggrin:
berdengung!! :biggrin:
stuck with cloth.. i think ur idling would be bad.. engine died intermittently..
if stuck with sumthing like potato or banana.. confirm can't start :wink:
So small cc cars really best not to fit with aftermarket exhaust system? Cuz seen some K-cars, with aftermarket exhaust seems to be
faster than stock K-Cars..
:biggrin:
What to do, there are sports cat too, but in bolihland will cost an arm and leg to install, so most rather remove it only...
---------- Post added at 03:30 PM ---------- 6 hour anti-bump limit - Previous post was at 03:29 PM ----------
same as mine.....:biggrin:
---------- Post added at 03:31 PM ---------- 6 hour anti-bump limit - Previous post was at 03:30 PM ----------
banana cannot lah, but potato can, but it starter strong enough it will shoot out the potato....:rofl:
---------- Post added at 03:32 PM ---------- 6 hour anti-bump limit - Previous post was at 03:31 PM ----------
Mod sure faster loh....
if u dowan loud sound, go for s-flow type muffler.....like the ones use on airtrek turbo.
---------- Post added at 04:54 PM ---------- 6 hour anti-bump limit - Previous post was at 04:53 PM ----------
for bullet put back the std ones......
Hi!! I'm new to tuning and I'm in need of advice!! My Perdana V6 N/A engine is stock running with a 6A12TT 4wd lock 2wd gearbox, exhaust current using the OEM setup with super dragger mufflers K&N drop in Air Filter and E manage
Now my “top GEAR KONG!!” (3 gears spin it up to 8000rpm++ 90 to 175km in just 6.3sce) (4 gear 220km++ )(5 gear _________) is it due to the TT gear box ratio or OEM exhaust diameter size?? Bigger throttle body size 70mm??
:confused:
Wah! Stuck with banana, terung, timun and all ?
Sure the mod will delete it!
Cos its way off topico, if you got what i mean.....:biggrin::listen::rofl::thefinger:
---------- Post added at 07:58 PM ---------- 6 hour anti-bump limit - Previous post was at 07:53 PM ----------
Can anyone tell what is the difference between a
bullet and a muffler ?
At first I thought both are same am I right?:idea::confused:
Bullet aka mid box is fitted in the middle. Muffler as it's name is the main item to quieten the exhaust note and always fitted at the rear end...
big bullet also can quiet ur car but u may have loss of torque...if im right
It is just like bigger pipe, less back pressure, but should not be as bad, as bigger piping is usually all the way to the rear, unless like some they do small in front and bigger at the rear, so have to tune according to your engine power....
just wondering, those exhaust exiting out at of the side bumper/front wheel legal or not? n does this kind of exhaust modification give better performance? i mean like this photo. :laugh:
confirm not legal..
i think this setup give better performance..
from the bottom of a nascar
http://image.popularhotrodding.com/f/project-cars/1975-laguna/16403732/dr-gas-exhaust-on-project-talladega.jpg
If you want side exhaust system design, one of the car you can consider, will be...
My friend did before, hell of a noisy.....:banghead:
